No head room for Headers
shag514
11-11-2004, 08:37 PM
Hey people...
Got me a 65 buick skylark, 2dr, hardtop coupe. Seems to be a fairly rare car. Originally had a 300ci buick v8, but is now powered by a 70's model rebuilt Chevy 350 small block. Mounted to the stock motor mounts. I'm looking for a set of full tube, shorty, or even block huger headers that will fit in that cramped little space. I need a set that will clear the screw in bushings on the upper A-arm and also clear the front cross member. No one has been able to help me out so far...Please HELP....
Puffnstuff
11-20-2004, 09:53 PM
Have you tried explaining your situation to one of the header manufacturers?
Headhunter1974
11-24-2004, 11:03 AM
Hi.
I also have a 65 Buick Skylark 2dr HT. I also swapped out the tired 300ci V8, and replaced it with 383ci stroked 350. When I did my swap, I had to change the engine frame mounts to those from a 65 Chevelle. The hedders that I used were hedman husler #65101. They might be a bit large for your motor, but any chevelle hedder should fit from 64-77 if you change the frame mounts. As for any clearance problem I didn't seem to have any, and mine are 13/4 primary. I also have a complete Global West front suspension pkg, with 12" disc brakes and tubular control arms..
I hope this helps.
Tim
I hope this helps.
Tim
