AIR DRIED BEEF DOG FOOD
some (probably simple) questions on my 2g CRX
terriblenone
11-10-2004, 06:37 PM
I'm fairly new to this forum and to the tuner car scene, so please bear with me.
I was checking some serial numbers today on my '89 CRX Si and came across a couple of things I had questions on...
I read the sticky post that had the VIN numbers explained, and I was wondering if its more common to have a CRX that's built in Japan or in North America. My CRX has some stuff under that hood that has Japanese writing on it as well as English (Rad cap, fuse box).
Another question I had was on my motor. After reading some sites on the 'history of the CRX' I was led to believe that the stock motor for the '89 Si had 105hp, but after checking the model number from my engine (D16A6) with the chart on this site, it says 108hp. Is this a case of engine swap? or do I somehow have a hybrid of the cars from 1988-1990? ('88's pillar mounted belts, '89's VIN, and '90's Si engine)?
I'd like to find out the history of my stock (as far as I know) Si. Any answers or comments are welcome!
NAte
http://www.cardomain.com/memberpage/710411
1990civicdxhb
11-10-2004, 08:37 PM
for starters you have a 4th generation CRX,
you wouldn't want a 2g!
I would say the most commons built in america/canada,
but 1st started in japan,every once in a while,you'll hear someone say they have a JDM civic/crx that was made in japan!
& to me,they are alot more faster then the 4g replicas,
& yes,I would believe that your crx SI has 105 hp
& you checked on another site that said 108hp,
but its only a 3 hp difference,its practicly correct!
but you could have a swap done in there somewhere......
maybe someone here in the AF has the exact same CRX as yours & could help you out with what came stock!
91civichatch2571
11-10-2004, 09:54 PM
uhh, actually its a 2nd gen crx.
2CrX
11-10-2004, 10:33 PM
You should have a sticker or plate(Cant remember which) under the hood that will say made in canada or japan. I have noticed most crx's are japan. alot of hatches are canada
But because it was built in japan for the us does not mean its a jdm(Read over priced trivial parts) car
TheSilentChamber
11-10-2004, 10:57 PM
1990civicdxhb most every thing you posted is false.
That is the correct motor, it is 108hp, Seatbelts were not mounted on the door till 1990, Your VIN will tell you where it was made. As well as it will have a Product of Japan sticker on the radiator support if it was made in Japan. Like 2CrX said, just because it was made in japan is not "JDM".
For the most part you have a stock crx Si that has nothing special about it. Sorry, you dont have some ultra rare needle in a hay stack.
crxlvr
11-10-2004, 10:58 PM
its definatly a 2g rex, since they were only made for 3 generations if you count the del sol(aka crx in other countries)
as far as the motor, 108 i believe was the si number for all 88-91's. and 99.9% sure it was made in japan, no early model honda was made in the states till i believe the 94 accord in ohio.
terriblenone
11-10-2004, 10:59 PM
Here's a copy/paste from this board:
A Quick Engine List
Since everyone always asks, "which engine can i put in my 4g?" heres a small list.. feel free to add to it.
direct bolt in engines: (least performance to most performance)
D15B1 -70hp
D15B6 -70hp
D15Z1 - SOHC VTEC-E
D15B2 - DPI, 92HP
D15B7 - 92-95 DX/LX, MPFI 105hp
D16Y7 - 96-00 DX, "DPMPFI" 105hp (?)
direct bolt in performance engines:
D16A6 or SOHC ZC - 108hp, great upgrade from DX/LX engine. cheap.
JDM D15B - welcome to VTEC. nice peppy engine, 125-130hp
D16Z6 - quick, with bolt ons should be able to beat alot of other sport compacts, 125hp
D16y8 - same as D16Z6 but 127hp
DOHC ZC - quick, similar performance to SOHC VTEC but DOHC NON VTEC, aftermarket support not quite as great as SOHC VTEC, 130hp
I've put my engine model in bold, and also what it comes at for hp. I found it on this site, not some other site, and I was just verifying it.
I know for a fact that its a 2g CRX. I think you're thinking Civic when you say 4g.
Thanks, 2CrX, for kind of explaining the whole 'built in Japan' thing.
NAte
2CrX
11-10-2004, 11:00 PM
No prob
turtlecrxsi
11-11-2004, 08:55 AM
I think the d16a6 from 88-89 had 105hp and from 90-91 had 108hp due to slightly more aggressive cam.
terriblenone
11-11-2004, 11:22 AM
Thanks for the clarification, guys.
Nate
clawhammer
11-11-2004, 11:39 AM
How are you supposed to be able to tell if it's ZC or just a plain D16A6
crxlvr
11-11-2004, 09:22 PM
check the id tag on the motor, tranny side just where the block meets the head.
skotman
11-11-2004, 09:35 PM
you mean 89, right?
TheSilentChamber
11-11-2004, 10:06 PM
Pretty sure it was 90, becasue the doors interchange between 88 and 89 without converting to a differnt type seat belt.
