clutch proablems
xavier3jr
11-10-2004, 03:15 PM
the clutch has no preasure but it is still pullin out of hte tranny is it the clutch fork or does it just need to be bleed, i heard a loud pop when i stoped workin so i duno what it could be
riff22
11-11-2004, 09:48 AM
have the same problem now 3 diffrent ppl told me it needs a new master cylinder. i ordered the maste and slave cylinder today it was 90 bucks total im putting it on tonight if i have time, i will let u know tomorrow what happens.
xavier3jr
11-11-2004, 02:18 PM
thnx man cuz i get my licens the 26th so im tryin to get my car fixed b4 then lol just wana try to find out hte problem before i pay money to get it fixed
riff22
11-15-2004, 09:22 AM
well i got it all in and it seemed to fix it, give it a shot. i have a new problem now tho some times the car will slip, i think the clutch is not fully ingauging, but it did fix the pressure problem. maybe i fucked something up puttting it on.
riff22
11-15-2004, 09:38 AM
ha just talked to my mechanic and i figured it out. when u put the master on there is a cylinder rod that connects to your pedal, and u can ajust it. my problem was it was pushing to much fluid into the slave and when u let off the pedal it sucks it back into the master, well mine needs ajusted. it needs shorted up sp that it dont push as much in and it will pull more back into the master. so there is some advise if u have the same problem i did. just keep it in a low gear to get home so u dont smoke your clutch then adjust it.......
xavier3jr
11-15-2004, 09:25 PM
well when i lost mine it made a popin sound....
and it wouldnt change gears i had to ride like a mile and a hafe in first gear to get home
riff22
11-16-2004, 09:16 AM
have u checked your clutch fluid? if its empty fill it it uses brake fluid. have someone pump it and look for a leak under the car...
xavier3jr
11-16-2004, 11:28 AM
yea its full
xavier3jr
11-18-2004, 04:43 PM
ok well i fianly took the time to actually get outside and look at wut could be wrong
i know its not my clutch fork or my slave cylinder ne other sugestions?
xavier3jr
11-19-2004, 04:15 PM
ohk my car is fixed!!!!!!!!!!!! finaly
mom went to auto zone today while i was asleep and bought a 280$ clutch i dont even know wut kind it was took it to my uncle and he fixed it turns out my master cylinder was bad also....
riff22
11-20-2004, 11:40 AM
good deal....
