clutch pedal!!!
riff22
11-10-2004, 09:42 AM
my 95 talon tsi wouldnt go in second gear so i took it to a shop and got the sincros fixed and went ahead and got a new clutch since the tranny was already out. the flywheel was cracked bad so the mechanic got that resurfaced.well i got the car back yesterday and it goes in second fine now, but the pedal has no preasure at all u have to pump the hell out of it. it seemed to get better on the way home, but havent drove it since. it was bleed i guess im going to try to re bleed it today. unless anyone has any ideas???????
thanks
`tyler`
1stGenRocks
11-10-2004, 07:59 PM
i would take it back and make them fix it. why spend your money and time fixing it yourself when they screwed it up?
riff22
11-11-2004, 09:28 AM
yea, well i looked at it tonight and i think it needs a new master cylinder, which wouldnt be his fault. just a coincidence that it went out at the same time i guess.
FoRCedInDuKsionGsT
11-12-2004, 12:54 PM
ANOTHER QUESTION ABOUT THE CLUTCH PEDAL....
When I push the clutch pedal down to shift it make a squeeking sound...how would i fix that? WD40 or somethin? Would there be a problem in the long run if it is not fixed? I know it's something with the throw out bearing but what do you guys think...
