Another Driveshaft Thread
2crunk
11-08-2004, 11:26 PM
I've heard all of the good things about aluminum driveshafts, but i have also heard that aluminum parts can tear-up your car. Does this include a D/S? And when someone says tear-up your car, what exactly can it mess up?
silverstangs
11-09-2004, 12:12 AM
The aluminum drive shaft is perfectly fine. People tend to have issue's when they get a aftermarket drive shaft that is out of balance. If the drive shaft is out of balance, you will get a vibration. Also after a period of time, it will wear out the output cup and shaft in your transmission. If you get gears, that will really make a out of balance issue show up because your drive shaft will spin even faster, so that weight will have more force. Think of a out of balance wash machine.
The balance issue can be with stock drive shafts too, not just aftermarket. I would reccomend that you also get a drive shaft safety loop, just incase the U-Joint ever breaks. That will prevent the front of the drive shaft from wedging into the ground, and catapulting the back end of your car.
I use a aluminum drive shaft on all of my mustangs, and it's a easy mod that usually smooths out the ride.
gmartinez
11-09-2004, 09:10 AM
Sorry, newbie question:
does an alluminium driveshafts really make a huge difference?
I've heard too that alluminium parts can tear up you car!!!
silverstangs
11-09-2004, 08:07 PM
As far as tearing up things..... only if they are out of balance, but it's not related to the material...... Otherwise the aluminum drive shaft wouldn't be a popular easy mod to do.
I made a mini Q & A a long long long time ago..
Read this.....
Rotational Mass (http://www.silverstangs.net/rotationalmass.html)
Read this.....
91notchback
11-10-2004, 12:36 AM
with the problems that i have ran in to is that the aluminum drive shafts are bigger in diamiter and my car is lowered and every once in a wile when i launch hard with passengers my driveshaft hits my floor pan. actuly it pinches my e brake cable into the floor pan. but i dont like having more then one passenger so i dont really mind that much
HiFlow5 0
11-10-2004, 01:38 AM
I have aluminum heads, driveshaft, roller rockers, intake, TB, etc. I don't see how aluminum parts can tear up your car.
