wierd shake!! help
viet_boiiiii
11-05-2004, 09:44 PM
welllllll today i parked my car on a high slope (my driveway) so i can clean my rims.. afterwards i went to take my lil sis home, at the same time i noticed that my front rotors r fucked up cause of that squeeky sound when i stop. well after i took her home i went out for a joyride .. i was doing at least 70-80 on a regular road. a couple mins later a freaking camero came along -_- he had a v8 so i didnt do crap but peeled off in front of him =) well after the joyride i was taking the long route back home. i noticed that during first gear my car rattles.. i was afraid this is the crank walk.. or is it? everytime or sometimes when i dont give the car enough gas it rattles.. this rattle is diff from other times cause other times its barley noticeable.. this 1 is real noticeable.. can any1 help me find out whats wrong or am i just tripping? the car doesnt rattle IF i feed it around 2500rpm at start off
97_3clipse
11-06-2004, 01:06 AM
is it a rattle you can feel or do u just hear it?
george536
11-06-2004, 01:44 AM
remember the 2g has alot of rattles. everytime i hit a bump i can hear my window or my sunroof, and stuff so dont really jump to crankwalk
viet_boiiiii
11-06-2004, 02:15 AM
the engine shakes the car.... i think its my driving habbit. sometimes when i drive barefoot it rattles cause i be letting off the clutch a lil too early. but i just noticed that today cause it felt like the engine was actually shaking the car.
*edit* yes i did feel and hear the rattle .. it scared me haha
riff22
11-06-2004, 11:54 AM
motor mounts maybe
david-b
11-06-2004, 01:38 PM
My back window rattles. It's crazy... the higher the rpm, the more it rattles. SOunds kinda cool actually. Gives a "surround sound" feel to the car.
I'm crazy
97_3clipse
11-06-2004, 02:14 PM
there was a fix on dsmtalk.com that shows you how to fix the 2g window rattle..
george536
11-06-2004, 08:04 PM
My sunroof rattles really bad. i hate it. But its coo. I can deal with it.
97_3clipse
11-06-2004, 09:28 PM
My engine shakes a lot! Is there a fix?
Search for this topic now!
Excessive engine vibration is a telltale sign that the balance shafts (also known as silent shafts) are out of alignment. These shafts are designed to counterbalance the engine to keep it from shaking during normal operation.
If the engine vibration just started, do NOT start or drive your car until you can verify that the balance shaft belt is okay. If the belt is old or worn, it can jump, causing the balance shafts to be out of phase. This, in itself, will not damage your engine, but is a symptom of much larger potential problems.
The real problem is that if the balance belt jumped, it may be getting ready to break, and could the next time you start your car. This in itself is not a bad thing (the car runs fine without the balance belt at all), but the balance belt has a nasty habit of hitting the timing belt after breaking. The timing belt will often jump or break after such treatment, which is, literally, an engine-destroying event. You can count on losing at least eight valves if the timing belt jumps, and probably all sixteen if it breaks. Repair costs can run into the thousands. It is for this reason that the balance shaft belt should be replaced at least as often as the main timing belt.
It is also possible that the engine will shake immediately after a timing belt change. This is indicative of a simple misalignment of the balance shafts in the engine. Running the car that way is not damaging, but is obviously undesireable. Return the car to the shop in question to have the timing re-done - driving it there is usually ok, although towing is great (especially if you can get the shop to do it). Read the timing belt VFAQ for more information. (Yes, it's listed in the FAQ Locator.)
Searching the archives for "balance shaft out phase" will pull up some more informative posts on the subject of balance shaft alignment.
-from-
"1000 Already Answered Questions"
