transmission
cathy_p
11-05-2004, 07:34 PM
My transmission started leaking like 7 months ago. I used Trans-X and it was alright until now. It got so bad I have to buy a new one.
Does anyone know where to buy a cheap transmission? ANy advice?
Thanks
1stGenRocks
11-05-2004, 08:16 PM
automatic or manual? where does it leak from? unless the case is cracked you probably just need a new seal
kjewer1
11-06-2004, 12:34 AM
Yeah, axle seals, or output shaft seals on AWDs, are like 7 bucks ;) For turbo tranny anyway.
cathy_p
11-06-2004, 09:23 AM
It is automatic. Mits. Eclipse 95
It would be great if it was only the seal. I am not sure where it is leaking from. I was told it is leaking and I should use Trans-X. It really helped. I got fixed my engine mounts 3 weeks ago and that is when it started doing it again. It forgot to change gear sometimes. I put two bottles of TRans-X in. It is changing gears now but when there is a hill I cannot drive faster then 20 - 25 MPH. If I want to press gas pedal more the car will stop, makes some kind of weird sound, jerks and I have to take off my foot and try it again. It also does when I drive more then 30 mins.
God, I don't know if you understand.
i took it to some car shops but they seem stupid to me.
kjewer1
11-07-2004, 07:47 AM
Shops usually are stupid. But if the fluid is to the full line and you are having the problems above (cars stops??) its probably time for a rebuild or replacement.
