finally hooking it up...
red96
02-22-2002, 03:28 PM
i know nobody cares quite as much as i do, but i had to tell somebody. :D
finally ordered my JDM B16A2 swap, and a DC Ceramic 4-1 Header to add to my AEM CAI and DC cat-back...plus i ordered a Zex nitrous kit and plugs...
i'll post pix whenever it all gets put in.
later.
bp
:alien2: drive safe :alien2:
later.
bp
VTEC_boi
02-22-2002, 03:55 PM
THat's cool man - congrats!
civicbabe143
02-22-2002, 07:07 PM
Congrats:p and good luck!!
:hehehe:
:hehehe:
Rice-Rocketeer
02-22-2002, 11:04 PM
Get someone to take a picture of your face just as the UPS man unloads the crate ;)
Darkwing
02-22-2002, 11:18 PM
wow dude, when you got it all hooked up, drop me a line. I'd love to take a ride!
PS- you need any help or anything I'll come over and we can both give a try at it; that is, if you are doing it yourself. We need to get together sometime anywho, as you are one of the few car enthusiasts around LR!!
I only wish I had the money to get what you got, I gotta work in baby steps :( :rolleyes:
one day my ship will come in...
yeah right! :bloated:
Brice
02-23-2002, 01:50 AM
Dude, that's bad ass. I'm happy for ya. :)
I know how you're feeling cuz I just bought my Hondata system....getting in a couple of days. I'm juiced about it... :D :smoka:
Anyway, congrats again!
fjt
02-23-2002, 11:04 AM
PSSSSSST PSSSSSSST....There is no JDM B16A2 engine...The b16a2 engine is an USA spec only engine for yhe 99-00 Civic SI.
Either they're trying to rip you off by making you believe that and sell you the engine at a higher cost OOOOR what you really meant is that you got a JDM b16 engine, not b16a2.
iLLuCiv99
02-25-2002, 10:02 AM
isn't the b16a2 the J-Spec Si-R??:confused:
fjt
02-25-2002, 10:33 AM
NEGATIVE....See, JDM spec engines dont have a number at the end. Only USDM spec engines has the number at the end.
Take as example the ITR engine
B18C and B18C5---> The 5 after the C(C5) means that the motor is the USA spec of the ITR
The JDM spec end with a "C" eliminating the 5 meaning is a JDM spec engine(B18C).
If you take a look all USA engines have a # at the end of the code while the JDM don't:
B18C1--->GSR
B18B1--->LS
B18C5---> ITR
B16A2---> SI
B16A3---> Del SOL VTEC
The JDM SI-R engine is a B16(92-95 SIR, 96+ SIR II)
B18C1--->GSR
B18B1--->LS
B18C5---> ITR
B16A2---> SI
red96
02-25-2002, 02:00 PM
hmmmm...actually i didn't even think about that till you said it. hopefully these guys are just listing them this way (with #'s) so it'll show up if you search for them or something...they better be sending a JDM, not a USDM or i'll be a little pissed...by the way, isn't there a way to check on the engine to tell if it's JDM or USDM?
later.
bp
later.
bp
fjt
02-25-2002, 02:53 PM
later.
bp
All engines has the code# on the block. It usually is below the valve cover,where the Cam belt is.
If it says b16a Its a JDM engine
If it says b16a2 its USDM spec engine(99-00 Civic SI)
You can also ask them, if they say b16a2 jdm spec then you'll know they don't know what theyre talking about.
later.
bp
VTEC_boi
02-25-2002, 08:56 PM
Cam belt?
If you mean the timing belt for the cams then - you must not know what you're talking about because the cam gears are on the opposite side of the motor than the block stamp.
ric
02-25-2002, 09:25 PM
just make sure it isnt a grey plug
fjt
02-26-2002, 07:51 AM
Originally posted by VTEC_boi
Cam belt?
My bad, youre right. i confused my SOHC engine with his B16(DOH). My engine has the code on the Timing belt,cam gear cover.
I forgot DOHC engines have the code on the other side...
My bad:D
Cam belt?
My bad:D
