2000ls Good Trouble Shooting
C5LS2000
11-03-2004, 08:56 PM
I am new to the Forum. The reason that brought me here was the check engine light and the airbag light on my wifes LS came on. And thanks to every body and their post they are both repaired. And i saved a ton doing it myself. The airbag light was caused by a broken wire going to a yellow conector under the driver seat. I cut the other wire, went bought a new conector and spliced it in, and good to go. The check engine light was caused by a bad coil.
el es
11-04-2004, 06:12 PM
awesome..... welcome to the land of enchantment.
nalore1713
12-08-2004, 11:04 AM
Hi, I hope you come back to this foru and see this message..
I have the same problem with my 2000 LS V8. There is a 2 cable connector under the drivers seat and one cable is cut. I believe is the yellow one. My SRS light does not come on at all, and there is a series of beeps (total of 4 sets of 5). The book says that is a SRS issue. Where did you buy the connector from?
How much did it cost?
Did you changed it or did someone do it for you?
Did you take the seat off?
Please help me.... This beeping noise is driving me nuts.
Thanks
Yoni A,
Thanks
Yoni A,
