codes 4 and 8
anthony90si
11-03-2004, 04:25 PM
ok i just replaced my dizzy. and now i am getting code 4(crank angle sensor) code 8 (tdc) ok so for code 8 i believe i just got to play with the timing but how about code 4. what does the sensor do, and how can i fix it.
thanks
thanks
Greenblurr93
11-03-2004, 06:54 PM
You got dizzy replacing what??? lol just playing, i assume when u say "dizzy" u mean distibutor?
krustindumm
11-03-2004, 07:25 PM
www.geocities.com/krustindumm/resources.htm
sounds to me like your distributor/wiring is fucked since both of those are located inside it.
gunnmen01
11-03-2004, 08:25 PM
yeah, both sensors are in the dizzy... was a new dizzy or a junkyard one? if its a junkyard one id get another....
gunnmen01
gunnmen01
anthony90si
11-04-2004, 02:23 AM
its a rebuilt one. does it mean that the dizzy is no good. the car seams to be running fine..
blkef
11-04-2004, 09:13 PM
the two wires on the ecu harness need to be switched around
gunnmen01
11-04-2004, 09:57 PM
dont go rewiring your ecu unless your really really sure you know what your doing... still sounds to me like its a bad dizzy
gunnmen01
gunnmen01
dirtybirddurant
11-05-2004, 10:17 PM
Did it die when it was just at an idle
anthony90si
11-08-2004, 03:51 PM
the old one died. but the new one seams to run ok
