Need A LIL Intake Help!!!
Technical_Automan
11-03-2004, 04:11 PM
I'm replacing the intake manifold gasket on a L98 350 Firebird and I got the plenum and runners off, all hoses and wire connecters marked and disconnected, distributor out, but a few of the TORX bolts that hold that hold the lower intake down to the head are hard to get at. The manual doesn't say to remove the fuel rail, but it's the only thing that's blocking the bolts and it has metal tubing that I don't know how to take off or move. So does anyone know if the fuel rail needs to come off or not? Or how to take it off? Because I removed the bolts that mount it, and it won't move, shouldnt the fuel injectors just slide out of it, or is there like a snap ring or something? thanks for any help.
FormulaLT1
11-03-2004, 05:21 PM
To remove the fuel line you need a special tool they sell at local auto parts store its called the quick disconnect fuel line remover. .. What it does is goes into the tubing and releases the tab's so it can be pulled out. Let me know if you need anymore info or help.
John
John
FormulaLT1
11-03-2004, 05:23 PM
Also the injectors can stay attached to the rail unless you feel like removing them.
