a request for advice!
DirtyD777
11-03-2004, 12:02 AM
Hello fellow crx and 4g civic owners. I'm calling on you all for some advice.
My crx has a weird habit of cutting out when you take it into high rpms (4-6000) when it's not warmed up..once it reaches normal temp it runs fine. EXCEPT sometimes for some reason even when it's warmed up when it nears 5700-5800 rpm it cuts out again...well lately it's started cutting out alot more..usually in 3rd gear..when i hit over 5k..today it cut out at 5500! I was pissed off because I lost to my friends civic hatchie because of this...I KNOW it's not the timing because that was just set w/ a timing light...plugs and wires are only about 2 months old..I really think it's air/fuel related..could my air/fuel ratio be off abit?? I don't know...any advice is welcome. Thanks in advance! :)
-Alan
BullShifter
11-03-2004, 12:07 AM
keep the racing on the track!
DirtyD777
11-03-2004, 12:57 AM
yeah..shame on me!
now anyone with actual advice?
EDIT: I wasn't gonna type this out but I might as well so nobody else has to get up on their horse and tell me about street racing.
1st: There isn't a track within a 500 mile radius of my town.
2nd: my town has a total population of about 3000...(montana lol)
3rd: my friend lives on a highway about 20 miles out of town..No traffic whatsoever.. and you can see it coming miles away if there is.. so we weren't endangering anyone else..except maybe the cows in the feild by the road..but they didn't complain.
So don't think I'm one of those morons who goes zipping through traffic weaving around at 80 mph w/ my fart can blaring...I hardly ever race anyone..and this situation was totally fine..and probably 80% of people on this damn site go racing down the street through traffic in 'yer fancy big cities'! lol
"end of rant"
now anyone with advice on my car cutting out?
1990civicdxhb
11-03-2004, 02:47 AM
mine use to cut out,when I hit 3rd gear,
it would make a quik zip sound(chht)
& shut down,
it was one of my sensors under the distributor,that goes into the head,
yours may be a different problem,
but....its advice
Civic Jim
11-03-2004, 04:16 AM
for the engine to "cut out" at that revs i dont think its air/fuel unless you have a blocked fuel filter?
could it be the dizzy packing up?
TheSilentChamber
11-03-2004, 04:36 AM
I think its the motor screaming at you to shift.
Hybrid1990crx
11-03-2004, 10:51 AM
yeah man, what motor do you have and what ecu are you running with it?
dagoEF
11-03-2004, 01:35 PM
Mine was doing somethin like that before, it would cut out at like 5500 rpm, then 5000 rpm, steadily got lower and lower. turned out to be the coil goin bad. I would also check the ignition module, they are both located inside the distributor.
DirtyD777
11-03-2004, 05:30 PM
well I'm going to look into the stuff you guys suggested..my dizzy is old it's from the old motor so I've been wanting to replace it anyways.
And the motor is a D15b (not d15b2 just d15b) not 100% what car it came from :/
w/ the dx ecu
thanks everyone for the advice :D
Figori
11-03-2004, 10:54 PM
Generally, the JDM motors don't have the numbers behind them.... :2cents:
DirtyD777
11-03-2004, 11:05 PM
Yeah I actually did know that.( how the usdm motors are stamped dif.)
I just haven't been able to find which civics came with the d15B.. one site said that 96+ civic cx's(?) had them so i dunno...anyways it's not a really saught after motor (i wonder why) lol.
And one thing I forgot to add is about 2-3 months ago my car was running like shit(the same cutting out thing) and throwing a code 1..so i put in new oxygen sensor and it ran great again..on the interstate when my g/f was driving the car about 3 weeks ago the code 1 flashed again..but no driving probs. so i just ignored it..could my o2 sensor go bad that fast? and if so what would cause it to crap out like that.
Also my battery is reeeally old, need a new one just haven't had the spare money..=( Would that effect anything?
thanks again for everyones help.
ad_rock82
11-04-2004, 01:46 AM
if your dizzy is goin bad then it'll cut out like that. mine was goin bad and it would miss even cruising at 4500rpm (B16A). my friends b16 cut out totally after missing a few times at high rpm and it turned out that his bearing in the dizzy cooked itself, melted the rotor and so it was going in a football shape instead of a round one and missing a couple of the contacts in the cap. not the same application, but the same principles...
02 could go bad fairly quickly if you gotta cracked manifold or cracks around the bung that'd let excess oxygen and moisture and all that stuff in...look for a red line and thats your crack, this may also cause some small miss' in your idle...
DirtyD777
11-04-2004, 02:44 AM
Well..I guess tommorow I'm going to get a new dizzy rotor and redo my o2 sensor connection w/ a saudering iron (it's one of those universal bosche ones that just splices in..checked the bung it's fine..I think it might be becaues it's getting f--ing cold as hell here and the wires are just spliced together..and dizzy rotors are cheap..if those 2 things don't fix it I'm screwed for awhile because I have bills to pay, lol.
Thanks everyone.
DirtyD777
11-05-2004, 12:20 AM
well fuck, put in a new rotor today..still happens..now it's starting to cut out at 5000 rpm. this is pissing me off..plugs are all fine. Could timing to far advance or retarded cause it? I don't possibly know how that could be it though..just set it w/ a light like alittle over a month ago. Any one who helps me figure this out you are my god!
KrisSmithRocks
11-05-2004, 01:45 AM
well i'm not sure which injection set up you have and if it's the multiport then it wont apply at all, but some of the D15s have sequential injection and if that is the case i would venture that the secondary injector ( the one responsible for delivering the extra fuel at high RPMs) may be clogging. If that happens to be the case you could probably pick one up at a junk yard for like $10. Don't know if i helped but it's just a thought. good luck!
DirtyD777
11-05-2004, 02:03 AM
It's dual point injection.
You're idea sounds good but I've already ran 2 bottles of injection cleaner through her and I can smell fuel AND my gas mileage is going to shit..so I think it's running rich. :confused:
someone suggested to me that if the fuel filter is clogged it can cause high rpm cut outs..but before i shell out 20 bucks for a new one is this even feasable?
I'm obsessive compulsive, this has literally been losing me sleep..lol..:(
TheSilentChamber
11-05-2004, 07:17 AM
yeah a dirty filter can cause cutout at high rpm, and fuel filter should be less than $20, I got one at autozone a while back for $11 I think.
DirtyD777
11-05-2004, 07:52 AM
okay well i just broke down and ordered some stuff...4 ngk spark plugs..they'll be better than crappy autolites I have in now. A new fuel fliter and a new dizzy cap for the hell of it. I'll post up results when I get em' in (as if anyone cares, lol)
I usually go to checker auto parts I feel ashamed for some reason when I go to autozone lol. Like ours is set up..so when you go in you have to walk through the ricer isle with all the fake siR stickers etc. I always like speed walk through so I don't look at the shelfs, lmao. Damn I'm typing another novel here. lates
DirtyD777
11-14-2004, 02:33 AM
AGH WTF. Brand new dizzy rotor/cap, fuel filter, ngk plugs AND wires..i've ran about 2 bottles of injection cleaner and I never use anything below 88 octane fuel..and still it comes...right after 5500rpm usually in 3rd gear...total cut out and can't accelerate any higher.
Could the timing being off cause this? I don't know if my timing is 100% set right. I took it to a mechanic once to set it and he was like "there's no timing marks here" I tried to tell him about the 3 marks on the pulley but he didn't listen..so he "set it by ear" and it seemed fine...reved to 6k and up to 81 mph in 3rd gear easy. It doesn't drive bad...no problems other than the fucking cut out at 5500.
SOME ONE :1zhelp: :1zhelp: :1zhelp: :1zhelp: !
DirtyD777
11-14-2004, 09:29 AM
bump for sunday..
and..300th post!! :D
BullShifter
11-14-2004, 01:10 PM
have you checked the ECU for codes?
http://www.binghamtonlife.com/manual/2gsm/images/91-11-26.jpg
It almost sounds like the distributor is bad, but that's an expensive item to replace if that's not the problem.
DirtyD777
11-14-2004, 09:10 PM
flipped up carpet, no codes. & that's always the 1st thing I check anyways.
could it be timing or fuel? I took it for another drive today. sometimes it cuts out @ 5500 sometimes..5800-6000..so it's not everytime. If it was timing/electricle wouldn't it happen all the time? I'm thinking it might be fuel..actually I'm thinking I don't know what the fuck it is, someone throw me a freaking bone here.
I'm tired of thinking about it anyways..I think I might just take it in to the Honda dealership and have them check the timing and set it so it's right for sure. anyone know how much they charge for that?
4G4D Store
11-14-2004, 10:15 PM
Well, if your gas mileage is getting worse, I'm guessing you're getting the right amount of fuel, which would mean both your fuel injectors are working ok. And if it was electrical (bad plugs, wires, cap or rotor) you'll notice your engine missing more at the lower rpms around 2k more than you will at 4k+, so I'm guessing you're plug wires, plugs, cap and rotor are ok. I doubt it's your battery or your distributor, cause it's still starting and stuff, so, the only thing that is left is either timing or distributor. Try retarding your timing a little bit and testing it - you may have a little loss of power, but if it stops your engine cut off, then you may have just had it set to far in advance. The next thing would be to see if you can locate a distributor. See if a friend has one, or even a junk yard that you can borrow and test with before you buy a new one - they usually run over $150 from my experience. But honestly I'm guess it's the dizzy.
DirtyD777
11-15-2004, 02:32 PM
well i retarded the timing with the distributor alittle and took it for a drive, seemed to run alittle better and didn't cut out so bad but still there..I'm taking it to honda this week to have the timing set so i KNOW it's right. they only charge 20 bucks so hopefully that'll be the end of it.
thanks to everyone who listened to my bitching for the last week or so and gave me advice. Unless the timing being set doesn't totally fix it then...I'll be back.
DirtyD777
11-15-2004, 06:07 PM
here's afew quick pics of the shit my exhaust spews out..usually when i start it, no it's not oil.
http://memimage.cardomain.net/member_images/11/web/647000-647999/647140_107.jpg
http://memimage.cardomain.net/member_images/11/web/647000-647999/647140_108.jpg
http://memimage.cardomain.net/member_images/11/web/647000-647999/647140_109.jpg
2ndb18
11-15-2004, 10:34 PM
my car spits the same stuff out. Im sick of my d15b2
turtlecrxsi
11-16-2004, 07:29 AM
Your car has tuberculosis!!!
DirtyD777
11-16-2004, 11:31 AM
:lol:
seriously though..it's like this carbon/gas shit..not oil so my cars basically just blowing my money out it's blowhole ...=(
turtlecrxsi
11-16-2004, 11:42 AM
If it's only blowing out when you first start your car then I wouldn't really worry about it. It's probably gas left in the fuel rail before you cut the car off so when you cut it back on it's the first to go. Did you change your fuel filter? I know you changed a bunch of other stuff already. Maybe you should check your return fuel lines to make sure there isn't a clog. Also, try not to cut the car off after putting your foot into it... ie. try to let the car idle for a bit before cutting it off.
DirtyD777
11-16-2004, 10:54 PM
well yippy..today code 1 (oxygen sensor) came back!
I replaced the o2 sensor about 2 or so months ago..and already it's gone bad? WTF
DirtyD777
11-17-2004, 11:29 AM
*bump* :banghead:
DirtyD777
11-17-2004, 09:19 PM
Buuump!!!
