how much power est
gsxeclipse97
11-02-2004, 11:37 PM
i just installed my boost gauge today and i was wondering how much power my car puts out i have an the boost peaks at 18psi and holds steady at about 15.5 i know that the evo holds about 17psi does any one have an idea
1stGenRocks
11-02-2004, 11:44 PM
what year? what model? what mods? read the "read this before posting a question thread" thank you
joemathews
11-03-2004, 12:13 AM
I assume you have a 97 GSX. If so, your car must not be stock to be pushing 18 psi. If you have a manual boost controller, turn the boost down to 16 psi. You're putting out minimally more power than stock.
gsxeclipse97
11-03-2004, 12:30 AM
i have a an kn air filter the people i bought it from put a flow master i removed the waste gate solnoid, i dont have a boost controller i just tested out the boost gauge
o*HeR()
11-03-2004, 01:01 AM
i highly doubt ur pushing 18
joemathews
11-03-2004, 01:15 AM
Why? I suspect by the "wastegate solenoid," he means the stock BCS. Without any boost control, he should be able to hit 18 psi no problem with those mods.
kjewer1
11-03-2004, 02:08 AM
Read his psot again, he's getting a spike to 18 psi but its set at 15.5. Very common on T25s and other small turbos. Power isnt much more than stock, it was rated at 14 psi roughly .
gsxeclipse97
11-03-2004, 12:11 PM
so im running about 230hp to 245 if im lucky
LandoAWD
11-03-2004, 12:35 PM
215ish
gsxeclipse97
11-05-2004, 12:30 AM
215ish my rear end, if i had the air box still on there and removed the tube to the outside of the car that would put me a 215, the evo in japan has 300+hp and it puts out 1.5lbs more boost than the evo here there is no way that it is 215ish
gsxeclipse97
11-05-2004, 12:34 AM
if i was running 18lbs why would i want to turn it down to 16 wouldnt 18 put me at 260 270, besides just driving normally i dont really get over 7 or 8
LandoAWD
11-05-2004, 07:24 AM
Think whatever you want. Your car has 800hp.
You have no clue what you are talking about.
real_madridcf
11-05-2004, 09:25 AM
:iagree:
GTPSPEED
11-05-2004, 07:41 PM
hahahah that was pretty funny,
kjewer1
11-06-2004, 12:57 AM
If we are going to do the gay "how much HP do all the benchracers think I have, holla" threads, lets try to keep them realistic please. These threads are banned on every other board out there worth anything. I dont mind them, I think you can get a reasonable estimate with enough data. But lets be real here, wtf.
JoeWagon
11-06-2004, 03:47 AM
If you held 18psi, you would want to turn it down for efficiency. Since it's a spike and you settle lower, it's fine.
RPM? That doesn't have much to do with horsepower in this case, but for the record 7000-8000 is way too high to shift on a T25.
I'll put my money on 220hp, but then again, what does it matter how much fake horsepower you think you have? Tell people you have 300.
EclipseRST
11-06-2004, 04:36 AM
i think he means psi joe...
but anyways if you want to know go to a dyno. end of story!
gsxeclipse97
11-06-2004, 06:37 PM
well that sounds a little more reasonable but does the temp of the air affect how much boost you can run i was running constant 17 earlier, also while im under boost my boost gauge makes a hissing sound. i dont think that it is suposed to do that do you know how i can stop that?
97_3clipse
11-06-2004, 08:14 PM
gsxeclipse97, I dont want you to ask any more questions untill u completely read all the stickys, did a seach on the fourms, read everything on www.dsmtuners.com , read everything on www.vfaq.com , read 1000 questions http://members.shaw.ca/costall/1000Q/ , and the go down to the book store pick up a $20 book on turbocharging, and then ,and only then come back here and post....
BTW: you probally didnt push the vacume line all the way on in the back of the gauge...
gsxeclipse97
11-06-2004, 09:30 PM
dsm tuners is a site to buy stuff half of the stuff on v-faq doesnt work and i cliked on the already anwsered question or whatever it is and i wouldnt let me on to do anything my computer also sucks so but thanks for the sites
and i did try to put the vacume hose farther in the gauge and made it tighter but it still making the nose really only when it is cold though
JoeWagon
11-07-2004, 02:35 AM
dsmtuners is the biggest dsm forum there is. it's not just classifieds. everything has been said there, if you know how to search. most of vfaq works. 1000aaq works fine. :)
1stGenRocks
11-07-2004, 04:38 PM
if your boost gauge still leaks try putting a hose clamp on it. that or you bought some cheap shitty ebay guage that the actual guage leaks.
gsxeclipse97
11-07-2004, 08:32 PM
i have an autometer so i dont think that its the guage but i try the clamps thanks
LandoAWD
11-09-2004, 10:59 AM
:screwy:
