Pointers / Diagrams / Help
plopper73
11-02-2004, 06:43 PM
Hi all, Our Starter in our 1999 Chevy s-10 Went this past weekend and we ordered one and it will be here Thursday, I am so nervous about replacing it. I am on a VERY limited income and this came at the worse time! (enough of sob story)
I am looking for advice or a diagram on how to Change the starter. If someone owns the Chilton or Hayes book, I would reimburse you if you could email / fax me the pages covering this. Anything I need your help!
Thank you in advance!
OverBoardProject
11-03-2004, 02:07 AM
THe first thing that you should do is check all the wiring going to your starter. I've seen several starters changed because of a dirty, or bad wire somewhere.
It's really illegal for any one to send you a copy of a page from a manual... but if you give us all an e-mail address you might just have the pages show up in your e-mail.
Your local Library probably has the books that you need too.
Good Luck
Oh the job isn't too hard, and you should be able to change the starter with just a metric socket set in less than an hour.
Good Luck
plopper73
11-03-2004, 06:11 AM
Thanks for the heads up OverboardProject My email is in my profile.
I will head to local Library to see If I can find those today.
I didn't mean to suggest something illegal.
Oh Its the starter for the past year we have been babying it, there is a flat spot and its stuck on it. We changed the plugs and wires Thanks again!
OverBoardProject
11-08-2004, 12:09 AM
Let me know if you got every thing that you needed to change your starter. I'm about to re-install mine, and I might be able to send you some photo's or something that might help
plopper73
11-08-2004, 12:51 PM
We got it changed, Need tiny hands to get the wires off, but in all it was a fairly easy job! Thanks for your support!
chcknugget
11-08-2004, 10:54 PM
How did you get the starter out? I was under the impression that you need to lift the engine to get it out of the passenger side wheel well... Your hints would be nice... ;)
OverBoardProject
11-08-2004, 11:05 PM
You have to remove the brace that goes from the motor mount to the bellhousing, then 2 bolts, and 2 or 3 wires. It's really not that hard, You should see my ford tempo diesel... now that's hard
chcknugget
11-09-2004, 12:18 AM
So do you still do the removal through the wheel well? If I had known that a year ago I would have done it myself!
