Installting a Tachometer on a 1990 D-150
fanworks
11-02-2004, 09:09 AM
How hard would it be to install a Tachometer on a 1990 Dodge D-150 with a 5.2l V8? What would it entail?
praisethelowered
11-02-2004, 09:21 AM
You would need to hook up a power lead, a ground lead, a switched power lead (only on when the ignition is on), and a trigger wire. The trigger wire can be hooked to the negative side of the ignition coil.
fanworks
11-03-2004, 06:47 AM
Let me make sure I am understanding this. The tachometer that you buy at the store will have the follow set of wires coming out of the back:
+ Power Lead
- Power Lead
+ Switched Lead
Trigger Wire
Which is connected directly to the negative terminal on the coil.
Am I missing anything?
praisethelowered
11-03-2004, 08:08 AM
+ Power Lead
- Power Lead
+ Switched Lead
Trigger Wire
That about covers it. Some tach's may combine the positive lead and the switched lead into 1 wire. Good luck and let us know how it goes.
