what to do ???? what to do?
canisay182
11-02-2004, 08:46 AM
alright I need some suggestions on what to do. Here’s the deal, ok i bought a 93 240 two years ago then I got in a small accident that I thought bent the frame so I decided that I would just use it as a parts car. so i bought another 24a 92(full suspension, fuel pump, intake, port-n-polish, full exhaust, body kit,vlsd,sr20 that came with it, injectors, and several other things) now here’s my problem. the 240 I just bought 1 year ago is starting to show signs of rust on the floor panel, door mounting area, a little on the firewall and a few other spots. now I was wondering if you think I should keep this car or fix the other 1 and swap all the shit over or will the rust spots (though very small now) be a big problem. I know I can fix the floor panel but the other spots I’m not sure about. now on the other hand the other car has quite a bit of damage the lt rear quarter panel is tweaked, roof is creased, windshield cracked, rt front fender is fukd, rt door is also fukd, and all the suspension from the rt side f/r is fukd but no rust and all the brokin shit on 1 is good on the other I’m undecided cause that’s a lot of fukin work. Am I fukd or just fukd really bad. any suggestions would be greatly appreciated and no buying your car will not help me
D-Bo
11-02-2004, 06:04 PM
if your original 240 is too fucked to use then don't try to fix it. you'd be better off doing the body work and keep the one with the good frame rather than fixing the old one and have potential for more serious problems in the future. if you want to put that sr into your old one after fixing the body, you never know if the referbished body will be good enough to handle the sr..
canisay182
11-04-2004, 08:10 AM
thanks bro thats what i was thinking just didnt know how big of a problem gettin rid of the rust would b
D-Bo
11-05-2004, 10:31 AM
probably not as much of a problem as trying to fix a frame
