NO HEAT!! Winter is on it's way!! HELP
EddieVchitown
11-01-2004, 01:10 PM
I have a 1995 Jeep Wrangler. Last Year my boss jumped started my car (left my lights on) and shorted out my car. I replaiced all the guses but my heat hasn't worked since. When I drive there is hot air coming out so I don't think it's the thermostat but the heater fan doesn't work! Any clue to what needs to be fixed?
Blair25
11-01-2004, 02:51 PM
There should be a seperate motor for your heater fan, you should be able to buy a used one and install yourself. I don't know about jeeps but I've done this on other vehicles.
EddieVchitown
11-03-2004, 10:28 AM
Is that absolutely the problem? I mean.. In your opinion. I'd hate to be running in circles about this. Also, is a junk yard the onlyl place to get a used one?
Blair25
11-03-2004, 10:45 AM
I don't want to tell you that the motor is blown out as a difinate answer but if there is still heat coming out and there is no other leaks or temp. problems the motor would be my best guess. I just bought a repair manual yesterday and it I looked up your problem, it looks like a simple install. If you have a fax number I could try copying the pages and faxing to you. As far as used parts, a junk yard I know does not have many jeeps in them for they are a popular item. I'm from Alberta Canada and we have a great place to get used parts, problem is they only ship inside Canada. The sight can be found on page 2 or 3 of this forum under title of "Great site for Jeepers and 4x4s" I'm not a master mechanic and would hate to give you the wrong info. Good luck.
gtmud
11-04-2004, 07:05 AM
To see if its your fan motor, disconnect the connection to it, check for voltage across the terminals, it will vary depending on the control setting. I believe that there is a resistor in line with the fan, a Haynes manuel should tell you all you need to know. You can also check the fan by removing it and supplying a direct 12 dc to it, to see if it works or not.
justin_smokey
11-09-2004, 09:36 PM
I also have a 95 Wrangler and blew about 10 fuses from hooking jumper cables up backwards (mud on battery) My heater switch is only thing still does not work, I have bought new control untis and everything still no heat on unit, blows heater fuse instantly, I ran a wire from my fuse box, to a fuse, to a toggle switch, to the blower motor (was green wire with white strip) follow it from behind your heater control switch, only 5 wires back there and splice into it, if you need a blower motor still I got a brand new 1 here, just send a e-mail. Thanks hope that helps
kathygarnerville
11-13-2004, 01:07 PM
Instead of fixing it yourself, though many are handy with car repairs, your car is not even 10 yrs old. I'd recommend taking it to a certified Jeep dealer to have them run a diagnostic to be able to properly repair it before the weather becomes severe.
If you're in NY, in the Rockland County area, go to Rockland Auto Plaza. They have a great service department
