Tranny fluid leak at radiator
Caribbean ZJ
11-01-2004, 07:44 AM
Just replaced the rad on the 93 4.0. After 4 days there is a serious tranny fluid leak at the lower hose section of the rad. Its really hard to see down there. do u think the rad is cracked or some clamps would do the trick. Its hard to see down there even under the vehicle
ChadEbert
11-01-2004, 11:50 AM
Tranny fluid coming out of your radiator? Hmmm...odd, but sounds like a tranny line is bad. If the radiator were cracked, I'd assume you'd see coolant, not tranny fluid.
Dale Aeppli
11-01-2004, 01:25 PM
HI THERE ARE 2 LINES RUNNING FROM TRANSMISSION TO RADIATOR, THERE IS A COOLING CHAMBER MOLDED :naughty: INSIDE THE RADIATOR IT COOLS THE TRANISMISSION FLUID IN TRANNY. THEY USED TO BE STEEL CONNECTIONS ,BUT SOME MAKES USE A DIFFERENT CONNECTION THAT SNAPS INTO PLACE THESE HAVE A O RING SEAL, THAT YOU SHOULD CHANGEBEFORE HOOKING LINES UP. HAVE THE ONES THAT PUT RADIATOR IN FIX THEM NOW BEFORE YOU LOSE TRANNY FLUID, AND RUIN THE TRANNY . DALE :naughty: :nono: :screwy:
glass
11-01-2004, 07:37 PM
Hi Grenada
I had a slight trans fluid leak at the lower radiator connection as well ,
mine s a 94 6 cylinder , the hose connected to the radiator with a screw in connection , it was slightly loose , I tightened it , difficult acess , but possible if creative , it fixed my leak problem ,
Caribbean ZJ
11-02-2004, 11:33 AM
thanks will reply when fixed. Jeep is parked for now, dont want to risk it. The lower radiator connection line, is that the pressure or return line?
Caribbean ZJ
11-02-2004, 11:40 AM
It is the seal in the line connector it seems. we put a new o ring into the end of the connector, still leaks. Gonna buy 2 new lines, F%!king fedex charges!
Caribbean ZJ
11-03-2004, 10:26 AM
this morn mech came, placed new o-ring into hose connection. no leak so far. He suggested getting new hose still since he's not sure how long it might last. Fingers crossed
