Is there a catch?
96CivicEX06
10-31-2004, 06:40 PM
OK I was looking on ebay because I was bored and I found a 2-channel amplifier that has more power output than a more expensive mono channel amplifier, check it out:
AudioBahn A8002T
200 watts RMS x 2 at 4 ohms
400 watts RMS x 2 at 2 ohms
800 watts RMS x 1 at 4 ohms
stereo or bridged mono output
Tri-way capable (Tri-Way Crossover (http://www.crutchfield.com/S-F8O3PmAuWr0/cgi-bin/ProdView.asp?i=127TM100) required)
MOSFET power supply
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
high gloss chrome plate finish with blue illumination
variable crossovers (50-750 Hz, 18 dB/octave high-pass, and 50-120 Hz, 18 dB/octave low-pass)
subsonic filter (20-50 Hz)
18 dB bass boost (switchable on/off)
preamp outputs
preamp- and speaker-level inputs
cooling fan
fuse rating: 30A x 2
11-3/8"W x 2-7/16"H x 13-1/4"D
warranty: 1 year
$185
AudioBahn A8000T
400 watts RMS x 1 at 4 ohms
800 watts RMS x 1 at 2 ohms
MOSFET power supply
two 30-amp fuses
50-120 Hz low-pass crossover, 18 dB/octave
variable bass boost (0-18 dB at 50 Hz)
variable (20-50 Hz) subsonic filter
preamp outputs
cooling fan
cobalt blue illumination
speaker- and preamp-level inputs
11-5/16"W x 2-5/8"H x 13-1/4"D
1-year warranty
$200
AudioBahn A8002T
MOSFET power supply
preamp outputs
cooling fan
warranty: 1 year
$185
AudioBahn A8000T
MOSFET power supply
two 30-amp fuses
preamp outputs
cooling fan
1-year warranty
$200
AudioGuy93DelSol
11-02-2004, 04:35 PM
If they are both brand new and in the box then both are great deals. Both amps retail for 300 on crutchfield...i love ebay, anyway, since i really dont feel like gettin into the details of the differences in power, go with the A8002T its more versitile and in your case cheaper.
GScivic7
11-02-2004, 07:22 PM
I hate Audiobahn, had a complete Audiobahn system once, never again.
96CivicEX06
11-02-2004, 07:31 PM
What problems were u having with them since I'm wondering whether I should get an Audiobahn woofer or an Infinity
turbcivic
11-03-2004, 03:42 PM
How much do you want to spend? There are much better woofers for cheaper yet they arne't the evryday brand you see in the stores.
96CivicEX06
11-03-2004, 05:59 PM
I'm all ears man, whatever information you got for me on quality products, I'm listening. I'm hoping to spend only $300-320 for an amp and 2 12" woofers shipped. I have a friend that has Infinity subs and they're pretty nice and cheap so I thought I'd go that route but if something's just as good if not better and cheaper, I'll consider that route too.
GScivic7
11-03-2004, 06:14 PM
They sound like absolute shit is the problem I had with them. Then a moron friend of mine hooked up a third sub, that I had sold to him earlier, and the amp fried. When you give an amp an ohm load it can't handle it will start clipping the signal. In most cases with quality products, the amp will be able to handle the load for a little while and your subs voicecoil will go before the amp does. Not in Audiobahn's case.
