Ls/ Vtec problem can you guys help me!
99EletronblueSI
10-30-2004, 12:49 PM
I have a ls/ vtec 11.5.1 motor with a gsr head. When I put on the timming belt and I try to turn the motor it dosent turn.. It does for 2 or 3 turn and its locks..What can it be?? Can it be the head or the block is deck (milled) that the valve is hitting the piston .Or can it be I put the cams wrong or something....Does any one any advise.... :banghead:
civickiller
10-30-2004, 02:26 PM
you do 2 ro 3 full turns which because oen full turn on the crank is only half turn on teh cam so 2 full turns on the crank is only 1 full turn on the cam, maybe its #2exhaust or #1intake valves that are hitting.
hows did you come to the conclusion that you had 11.5 cr ?
99EletronblueSI
10-30-2004, 02:43 PM
But how can it be that the valve are hitting ? is the head not sitting right or what...?
civickiller
11-02-2004, 04:43 PM
the valves are hitting the pistons, the pistons dome is too high or cams too much lift.
thats why i asked how did you determine your cr is 11.5 ?
