Crown Vic with Marauder parts
jasong145
10-29-2004, 11:52 PM
I want foglights on my 94 crown vic and 99 grand marquis. would fitting a marauder bumper on the marquis and vic work and fit? and for the marquis, would the rear lights from the marauder fit right? thanks.
landyacht
10-30-2004, 05:05 PM
Fitting the Marauder bumber should work, that will certainly save you cutting holes in the bumper to get the lights to fit right. Just make sure you are fitting the Maurader fog light on thee aswell. Then it'll simply be a matter of wiring it all up correctly.
As for the tailights, i don't know if the Maurader ones will fit... you'd have to check with the dealership's parts department to see if parts are the same is my thought on that one.
Hope that helps!
Hope that helps!
