1997 transmission in a 1994 ?
robbbbb
10-29-2004, 08:53 PM
Will a 4 cyl 1997 transmission bolt directly to a 4 cyl 1994 engine? my trans is cracked and i may be able to pick up a 1997 trans.
tnx,
rob h
fredjacksonsan
11-02-2004, 10:30 AM
Not 100% sure, but sounds like you've got it apart; so measure both and check the length of the trans from front to end of tail shaft, and also bolt patterns on bell housing and mounting points. Also make sure the output shafts match up in size and # of splines.
