FronT Bracking Grinding Noise
Claypool
10-27-2004, 12:47 PM
Could use some advice on this. Have 01 Malibu with 52K mi. Had a front brake job about one month ago. Since then, I get a slight grinding noise when I come to a stop. Car Brakes OK though. Had it checked where I had the work done as I wanted to make sure everything was OK. I was told All OK in the front but the back wheel cylinders are starting to leak slightly and the front brakes are doing most of the braking creating a glaze on the rotors which accounts for the grind noise. Bottom line, suggested I replace the cylinders, brake shoes and bleed brakes. Cost $>300. Any thoughts on this? In reading this forum, I am aware of all the other issues with this model. Is it time to shake this vehicle loose?
Claypool
Claypool
bcopeland
10-27-2004, 04:59 PM
Sometimes people place a plate on the back of the brake pad. If this comes loose, it will cause a grinding sound.
malibugtp
10-27-2004, 05:49 PM
just replace the drums with disk brakes i did it for less then 300
bcopeland
10-29-2004, 09:08 AM
Well I would sure love to do this for my car. Did it also cover the ABS? What are the steps and how did you do it?
malibugtp
10-30-2004, 06:52 PM
91celicaFB
10-31-2004, 08:48 PM
or just take it to another shop and get a second opinion. Brake shops are notorious for ripping people off around my town.
