Gauges
LXDSMXL
10-26-2004, 03:38 PM
We are shopping for gauges for a stock 95 gst. We got a three pod pillar we know we need a boost gauge but, what would be the best next two gauges to buy, a A/F gauge, a oil pressure gauge, water temp gauge etc,, we only have two more to choose but...
what do you guys think we should go with?
Hpnotiq86
10-26-2004, 04:20 PM
A/F and a temp gauge. You need to watch for heat problems.
joemathews
10-26-2004, 05:09 PM
Oil pressure and water temp would be good. If you have big plans for the car, you will want an EGT gauge at some point.
david-b
10-26-2004, 06:16 PM
Voltage and A/F
1g90gsx
10-26-2004, 08:49 PM
i would suggest oil pressue,boost and an egt.a lot of people dont think about the oil pressure gauge but once that oil light comes on its really about to late or dam near close.
joseseclipse96
10-28-2004, 10:01 PM
u need to run air fuel ratio, oil pressure, and boost.
gthompson97
10-28-2004, 11:37 PM
i would get the 3 pillar gauge pod and then the 2 gauge pod made for your stock gauge bezel. then you can fit 5, boost, a/f, volt, oil press, water temp
real_madridcf
10-29-2004, 07:37 AM
Boost is a must; Oil pressure and A/f are not bad to start w/. Depending on what you have planned on your car, you prob are gonna want to get an EGT too. Also what kind of guages are you going for, Autometer???
Good Luck!
Hot2Trot
10-29-2004, 09:18 AM
I'd stay away from a A/F gauge. Unless its corrected from Lowtek or someother shop.
They are worthless rice bucket light shows. Don't waste the cash.
Get a Palm Pilot for cheap. A logger cable and software ($150) from digital tuning and run a boost gauge (For boost and vac refrence) , Oil pressure for the obvious and a EGT for the obvious reasons.
Anything else is kinda a waste of space.
Urban_Squrill
10-29-2004, 12:49 PM
If you are planing on running a nice audio system I would suggest a volt meter. They are handy.
