Oil Pressure???
Nigel215
10-17-2004, 06:48 PM
I just changed my oil yesterday. Did every thing as I always do. This morning, I realized that my pil perssuer gauge was moving alot. I dident know if it always did it or if something is wrong. Heres whats happening......
From a complete stop it sits at about 40, then when i start driving it goes up to 60. Then when i step on it it goes all the way up to 80. I dont rembering this happening before. Any one know why this is happening ??? or have i just been ignorant of this before? Please let me know.
acbaer
10-17-2004, 08:13 PM
I don't recall mine moving too much on my 2004 5.3 V8.
Ape0r
10-17-2004, 08:49 PM
With my 5.3 it sits around 40 at idle, and at 2000rpm it is around 50-55. I can't recall it ever reaching 80, but then, the very few times that I've run it past 4000 RPM, the oil pressure gauge was the last thing I was paying attention to! The manual states that anywhere in the "normal operating range" is fine.
broughy84
10-17-2004, 08:58 PM
It's fine....don't worry about it...Everything sounds good. if you are worried about it, take the sender out, put a tee on it and add a manual pressure gauge. You need to keep the original inthere because the computer works off that signal i believe.
Nigel215
10-18-2004, 07:32 AM
ok...thanks...drove into work this morning and it dident go as high. It only went from 40 to about 65-70. But if everyones thinks its not a problem i wont worry about it. But if it is...you are all held responsible.........just kidding
jeverett
10-18-2004, 08:48 AM
GM says that all the pressure their engines need to lubricate properly is 5 psi.
