b16 idle problem
hmotorpimpn05
10-17-2004, 03:23 PM
ive got a 93 civic with a b16a swap in it and i am having an idle problem, it will idle at about 700 rpm consistently. i am using the pr3 ecu. any idea or suggestions would be greeatly appretiated
GScivic7
10-17-2004, 03:53 PM
it's supposed to idle at 700 rpm...this coming from the person who can rip on my sentra :headshake
Beastiek2
10-17-2004, 03:54 PM
Yea swap out the ECU. We had the same problem 2 weeks ago on on a b16a with a spoon ECU - we put the stock one back in and it fixed the idle problems - try it out goodluck
Beastiek2
10-17-2004, 03:55 PM
On mine it was idling low then shutting down, couldnt even drive it.
GScivic7
10-17-2004, 03:56 PM
jesus what do you guys want it to idle at? We had an idle problem with my friend's b16 too. Was idling at like 1500. Swapped the ecu and adjusted it down to about 700-800 and it was running perfect.
GScivic7
10-17-2004, 03:57 PM
your shit was dying idling at 700??? what was it idling at after you swapped ecu?
Beastiek2
10-17-2004, 04:00 PM
about a grand. We would put the car in gear and it would stall. We were freakin out. We brought it to the speed shop hea, and they were like yea ECU problem. So they put the stock back in and it worked fine. Beats me.
GScivic7
10-17-2004, 04:03 PM
never had a problem with it dying idling at about 700...weird. We were using a PW0, but I guess it had been messed with, ghetto ebay chip, so we got a PR3, played with the idle screw and shit was running good.
hmotorpimpn05
10-17-2004, 04:18 PM
which ecu comes stock with the 99 si civic
hmotorpimpn05
10-17-2004, 04:20 PM
with mine its sputtering a bit when it idles, the tachometer will elivate up and down between 500 and 800 rmp
GScivic7
10-17-2004, 04:26 PM
P2T
that can be a number of problems. Could be your IACV, leaking vacuum lines.
P2T
tomsindahizouse
10-17-2004, 04:30 PM
the 99-00 civic si ECU wont help you either, because its supposed to idle between 600 and 800 rpm, if thats the ecu your using, it might be another problem.....maybe its not getting enough gas, or oil, or your timing is probably off.
Beastiek2
10-17-2004, 04:35 PM
Is the p28 ECU stock in your car? Just asking I dont kno why that rings a bell .
Yea p2t GSCIVIC7s right for 99 si
hmotorpimpn05
10-17-2004, 04:36 PM
i am using the pr3
i am using the pr3
tomsindahizouse
10-17-2004, 10:48 PM
i have no clue what ECU I have....ive never needed to know yet.
