Unable to put into drive when cold(below 40 degrees)
wstull
10-17-2004, 12:40 PM
97 Malibu won't shift out of park untill engine warms up for about 15 min. when temp. is below 40 deg.. Doesn't appear to be a problem with the switch on the brake peddle. Any Ideas where else to look? Are there relays involved?
mattjordan
10-31-2004, 11:22 PM
linkage?
wstull
11-07-2004, 09:01 AM
Turned out to be a lock out solinode (spelling) under the console. Lubricated with silicon spray (shotgun approch) from under the dash and got fixed. Works fine now at even lower temps..
