1998 Vortec 350 Intake Manifold
PSBarton
10-14-2004, 01:12 PM
I recently replaced the coolant connector on the stock intake manifold of my 1998 Chevrolet Vortec 350, but when I did I tightened it down too much and cracked the lower intake manifold. Until this happened I had a pretty good record of not being an idiot. However, I guess it was inevitable that I would revert back to my true self. :banghead:
Anyways, I checked with the dealer about a replacement and they wanted $600+. I thought that was excessive and tried to buy two different ones on Ebay for about $60. However, both times I was outbid. Since I am not having any luck on Ebay I was thinking about buying an aftermarket intake like an Edelbrock.
Does anyone have any advice on what I should buy? I am not interested in hot rodding. I would like it to perform well for the highways and towing.
abaird
10-14-2004, 02:02 PM
Sorry to hear about your problem. We all do dumb things. I was looking around on the edelbrock website and I couldn't find a stock replacement intake. That doesn't mean they don't make one, I just might not have been able to find it on the website. If they do, one in the idle-5500 rpm range would be ideal. If not, I would keep trying with ebay or maybe a salvage yard. Keeping it stock if you liked it that way. Good luck!
skipr
10-15-2004, 12:02 AM
The fact that you where outbid twice may void your commet about you being an idiot. Why is there such a competitive bidding on a engine part that is supposed to last a long time. Could it be that these are cheaply made junk (like General Motors cast aluminum door handles, or that cheessy plastic upper manifold). A die cast intake manifold... what you need to make parts like this cheap, inferrior material. So why does the cost of vechicle inflate so much every year? There saving a fortune on crappy OEM parts. Oh I think maybe it's for more pocket cash for the upper management executives....No that would never happen in american corporations......LMAO
Jed Rule
10-15-2004, 08:22 PM
Try DORMAN, they make replacements for the 3800.
PSBarton
10-18-2004, 10:01 AM
Thanks Guys. I decided to use a product called Quick Steel to repair the crack. I figured if it didn't work I was only out a few bucks and a little bit of time. I put it on this weekend and to my surprise it is not leaking anymore. Hopefully my quick fix will last.
