Motor swap help
Robs71Nova
10-13-2004, 02:07 AM
Ok guys. I was wondering if any of you have had experience dropping a big block into an originally small block car (CHevelle, Nova, Camaro). I am doing this swap in my 71 Nova but I am running into some problems in the oil pan area. Now granted when I went to drop the motor in the car I was using the oil pan that came with the motor(truck oil pan out a 85 suburban) but I was wondering if anyone had any recommendations as to which to buy. I was having a problem with the pan hitting on the frame. WIll a flatter "drag racing" (flat witha big square at the back) cure my problem? Any info would be sorely appreciated. Thanks
Rob
MrPbody
10-13-2004, 07:45 AM
You might try the Chevelle pan. It is different than "big car" and truck. The crossmember is in the way. A call to a Chevy dealer or Chevy specialist can tell you whther or not the BB Novas used the same pan as the Chevelle. There were a few SS 396 Novas in '69/'70.
