5.0L 342 stroker motor
joey17
10-12-2004, 11:12 PM
does anyone know where to get a 5.0 stroker motor an the great t-5 for cheep , an i looked at a 7.5 and i was wondering if it will fit in my 95 conv. without being a real bitch.....
NO MONEY, NO MOTOR, NO PUSSY! LIFE SUCKS
PLEAZE HELP :banghead:
StangNut86
10-13-2004, 12:27 AM
i've said it before, and i'll say it again. should go in my sig...
Good, Fast, Cheap, pick 2
good + cheap = not fast
fast + cheap = not good
fast + good = not cheap
if you try to put a 'cheap' 5.0 stroker and a 'cheap' t-5 in a car, you won't have good results. for one thing, a stroker motor is difficult to find, as they're all in cars or blown up. you really should get a block, reinforce it a bit, and use it as a basis to build a stroker motor, which won't be the slightest bit cheap. you're much better off finding a stock 5.0 and putting it in your car. and get the best transmission you can find for the money you can spend, the better shape it's in the happier you'll be.
i'm not sure what you meant by 'looked at a 7.5'. if you're referring to the rear end size, not a good idea, a 5.0 will break it.
if i sound like an asshole in this post, it's not intentional... i'm just telling it like i'm seeing it. good luck.
351wStang
10-14-2004, 05:51 PM
No such thing as a 342. 302, 306, 327, 331, 341, 347, ar the basics, then you get into .020, .040, .060 bores.
boosted331
10-14-2004, 05:57 PM
342 is a 347 crank (3.4" stroke) in a standard bore block.
StangNut86
10-14-2004, 06:30 PM
yeah but who the hell uses a standard bore block, really? i'd say that most guys either use a stock block that's worn and needs boring, or an aftermarket block that they punch out for extra displacement.
NIN881
10-20-2004, 04:14 AM
How much power can a reinforced block handle. I wan't to put 400 or more to the ground.
351wStang
10-20-2004, 09:48 PM
I was thinking that a 4" bore and a 3.4" stroke measured out to a 341. Never heard of either being used though. Nothing wrong with slightly thicker cylinder walls though.
