TCS light
Hector munoz
10-11-2004, 09:32 PM
I am having problems with my 95 millenia. My tcs light seems to only go off when i am on the highway, causing my car to hesitate when i try to excellerate. Once the ignition is turned off, the tcs light turns off and car runs fine. i have already replaced: bank1 oxygen sensor, fuel filter, air filter, brake job, pcm (computer) the dealership can not pin point problem and i am running out of cash
Daprodukz
12-19-2005, 02:44 PM
I am having the same problem. is there anyone who has an answer to this?
mazdatech177
12-22-2005, 03:39 PM
you more than likely have some broken vacuum tees under the intake manifold. you need to have these repaired. you may also have malfunctioning vacuum and vent solenoids for the ABV system.
bs092164
07-06-2006, 11:30 AM
My 96 Millenia S has the same problem. Warmer weather seems to aggrevate it. I will be driving along just fine, I feel a slight loss of power, the TCS light comes on, and then the car starts chugging down the road if do more than just slightly accellerate. For $1200 my local Mazda dealer said they could fix what it "might" be. Would love to find someone who figured this out!
caribeno
07-29-2006, 06:43 AM
I am having the same problem. Did you finally fix the problem?
mazdatekchubyninja
08-06-2006, 06:31 PM
Are you guys deft. Mazdatech177 told you the answer. It's caused by broken vaccume tees under the intake manifold and possible solinoid for the ABV system(AIR BYPASS VALVE for your supercharger)
mazdatekchubyninja
08-06-2006, 06:32 PM
upsy I ment blind
bacbrakr
01-28-2007, 12:46 AM
Thank you for this info. I just purchase a 96 and the light was popping up as soon as i took it off of the lot. I took it back with a print out of your postings and the TCS light and they were able to fix the problem.
Mow if someone can tell what to change for the car not wanting to start, that would be great.
Thanks again.
Thanks again.
