Waterpump Causing Vibration ?
Caprice Master
10-11-2004, 05:42 PM
Hi,
On my 85 Caprice with the 305 engine, my waterpump has a pretty worn out bearing. I haven't replaced it yet, for various reasons. Lately I've noticed a vibration in the accelerator pedal and steering wheel on acceleration sometimes. If I rev the engine in neutral, I get a rough vibration too. My question is : Could the vibration be due to the waterpump bearing going out?
Thanks
Thanks
TommySS
10-11-2004, 06:08 PM
Anything is possible, but it's probably not the water pump causing the vibration.
Check your power steering fluid level/condition (make sure you have enough and that it's not full of dirt/metal).
Other sources of vibrations are misfires and vacuum hose leaks.
Is it making noise?
Is it making noise?
Caprice Master
10-11-2004, 08:54 PM
It's not making any noise associated with the vibration, no.
TommySS
10-12-2004, 07:15 PM
Dag!
Have a look at the crank dampener. It's made of rubber/metal. If the rubber separates, it's not doing its job anymore. It would explain why it vibrates at idle, moving or not.
Caprice Master
10-20-2004, 04:48 PM
Life is good. I put in a new waterpump and the vibration went away ! :smokin: :rofl: Took me 7 hours, but I enjoyed every minute. :smile:
TommySS
10-22-2004, 06:39 PM
Congratulations !
That pump must've been REAL bad to cause vibration like you describe
