93 Escort Dashboard instrument lights
towser42
10-11-2004, 10:14 AM
I have a '93 Escort (1.9L engine) and all my instruments lights are burned out The shiftpoint idiot light (it was the last one) just went out -- although that's not one I particularly miss.
It looks as though I should be able to get at the instrument panel by just removal the clear plastic window, or some portion of the panel, but when I look in the Haines book it seems as though I have to remove the steering wheel and steering column cover and everthing else just to get the instrument panel off. It looks like an 8 hour project.
Has anybody bothered replacing these lights? Is there an easier way? 'Cause right now, it seems better to live in the dark.
Thanks much.
Frunobulax
10-11-2004, 10:49 PM
Even with removing the steering column and cover, it only took me a couple of hours to do it on my '91. The cover doesn't have to come off, but it's a bear getting the black panel surrounding the instrument cluster out of there with the cover on.
I read that you could avoid removing the wheel and cover by dropping the wheel and column after removing a couple of bolts under the dash, but I've never tested it to find out if that's true or not.
I goofed, though -- I replaced all the bulbs, included that stupid shift indicator idiot light...doh! :)
turtle725
10-12-2004, 12:34 AM
Oh hey yeah Frunobulax is right, I remember now a freind did mine for me and it was done in a half an hour or so he just dropped the steering whell columm with those bolts. I couldn't remember how we did it untill you said that. Hope that helps towser42
towser42
10-12-2004, 08:43 AM
Thanks guys, I'll have to look into that "dropping the steering wheel" trick. It sounds like a good timesaver. Does the entire dashboard have to come off, or is it only a section?
Thanks,
turtle725
10-12-2004, 10:31 AM
I think you just have to remove the intrument panel their are four or five screws. then just pull off the cover.
