Head Lights Needed
CIVICDX247
10-10-2004, 09:58 PM
i bought a 93 civic dx hatch back, with some body work needs i have finished the work needed to be done and now all i need are head lights
wondering if any one had any stock or aftermarket lights they would be interested in selling me.
im hoping to get maybe the halo angel eye projector lights, but they are to damn pricy even on ebay.
if indeed someone could help me out and point me in the right direction i would highly appreaciate it
but as of right now im looking for some stock lights just so i can atleast drive the peice of beauty,
let me know.
let me know.
Silverbolt
10-10-2004, 10:08 PM
do a search in the classifieds, and look on Ebay.
CIVICDX247
10-11-2004, 05:17 PM
i have been looking on ebay but like i said if im gonna buy them on ebay im just gonna end up wasting money because i plann on getting halo algenlee projectors for my civic.
never tried classifieds though, thanks
eckoman_pdx
10-12-2004, 03:09 AM
Try calling around the junk yards and asking for prices on headlights also. If you have any U-Pul-It junk yards around with your year civic in it, just go down and pull the lights off yourself. Parts are very cheap in a u-pul-it yard.
Just curious, how much are you looking to spend MAX on a pair of headlights?
Geeko
10-12-2004, 10:46 AM
there are also place that manufacture OEM-style replacement headlights for cars. when i repaired mine from the deer, i bought one that looks dead-on like OEM for 125 bucks, vs. 250 from Honda.
Zc_Crx_91
10-21-2004, 09:48 PM
Speedpeople.com Or Jhpusa.com Or Jdmshit.com
Shiftee97EX
10-22-2004, 06:22 PM
How much do you have to spend?
I just picked up some angle eyes for $135 including shipping on ebay. That also included all the bulbs.
civic4me
10-30-2004, 11:00 AM
hey shiftee.....cuz im having this problem....how does it say to change out the low beam bulb when it goes out?
eckoman_pdx
11-03-2004, 05:49 AM
Are you asking how to change out the low beam bulb on angel eyes when it goes out? The BULBS can be changed when they go out. The LED "angel eyes" CAN NOT. When those go...sorry...gone.
Your low beams are probably H3's if you have projectors/angel-eyes. Your high beams are probably H1 or 9005. Replacing headlight bulbs is quiet possibly the easiest thing you will ever do with a car. You replace the low beam bulbs buy:
a)buying proper set of correct bulbs.
b)make sure ignition is off, lights are all off
c)remove rubber/plastic cover cap (usually it's a rubber cap cover, though I have seen a few companies who use plastic) that cover the low beam side opening on the backside (inside the engine bay) of the headlight housing.
d)remove headlight bulb. H3 bulbs will have a metal clip that holds the bulb in. remove the clip, and carfeully remove the bulb. WITHOUT TOUCHING THE GLASS PART OF THE BULB, remove where the bulb/bulb wire connects to the headlight housing wire.
e)WITHOUT TOUCHING THE GLASS PART OF THE BULB, carefully connect new bulb to the headlight housing wire connector you just rmeoved the old bulb wire from
f)pull rubber boot back over connectors, put H3 bulb back in place (or whatever bulb it is you have) ,place metal clip in place over backside where it goes (if applicable). Replace rubber/plastic cover cap.
