AIR DRIED BEEF DOG FOOD
Alternator from a CRX DX bolt up to a ZC?
CR50HC
10-08-2004, 04:10 PM
My alternator is whining on my DOHC ZC. I have the old alternator from my original D15B2 engine. Will it bolt right up to the ZC's block without modification? If it will not, what make/model of car do I need to search for an alternaor off of? I would "ass'u'me" an 88-91 Integra? If this helps, my ZC in an 88 Model.
Troy
91civichatch2571
10-08-2004, 04:51 PM
it will work fine. bolts right up and all that good stuff.
CR50HC
10-08-2004, 05:10 PM
Sounds great! So, there's no difference in mounting brackets or bolt locations?
91civichatch2571
10-08-2004, 05:17 PM
nope
CR50HC
10-09-2004, 01:07 AM
Thank You! You have saved me some money. I really appreciate it!
Troy
CR50HC
10-21-2004, 02:14 PM
Problem solved! I pulled my old alt from my 89DX and put it on the DOHC ZC. Everything is now quiet under the hood... Thanks for the help!
V-K
10-21-2004, 04:31 PM
My alternator is brand new, and it whines like a bitch. I've had it tested and it works great, other than the noise. Is this something I should worry about?
dagoEF
11-09-2004, 04:44 PM
Will the d15 alternator work on a b16? If I understand right, it will as long as it's non-obd, right?
