97 Taurus temp control
Hammer90
10-08-2004, 11:37 AM
Hi, guys and gals,--searched every thread, but couldn't find problem like mine. The dial control for the hot/cold doesn't seem to work. All other controls are fine,but my problem is I ONLY get heat as opposed to everyone that can't seem to get heat. Figure its the control itself--how do I get the darn panel off to replace it---or do you think it is something else causing the problem? Thanx---later
drdisque
10-08-2004, 06:29 PM
is it HOT everywhere on the dial not just warm? When you turn on AC does it get colder?
I don't think the problem is the panel itself, I think its the door that diverts the airflow over the Heater core.
Hammer90
10-10-2004, 12:01 PM
Doctor, no matter where i turn the control dial the temp remains the same ---always hot---A/C control has no effect--nor does the vent setting--continues to blow hot air no matter what--later--Hammer90
drdisque
10-10-2004, 01:17 PM
then I'm thinking either the dial is disconnected on the back or corroded or the heater core air door is broken or stuck (which is a pain in the ass to look at)
Hammer90
10-11-2004, 07:07 PM
Thanks. I'll try the control first, but one more question ---Is there a special tool to release those spring clips that hold the faceplate for the climate controls. I popped a stereo out of my Explorer once using 6d finish nails, but there has to be an easier way, no? I am a fast carpenter, but only a half-fast mechanic. Later......
fastcar_racer
05-18-2007, 12:06 AM
Hello! Guys. I'm just new here. Looking forward to spending time with you.
_____________________
Kitchie
Download Hewlett Packard service manuals (http://www.manualshark.org/b/hewlett-packard-28/)
