how much power??
ImPLiCiTS14
10-07-2004, 07:12 PM
with the following turbo kit what can i expect out of a 96 5 speed @ 10 psi??
Not good with trims etc on turbos. TatII maybe u can help.
T3/T40E
3" Inlet Diameter
2" Outlet
.57T Compressor Wheel
.50 A/R Compressor
.63 A/R Turbine
Spearco Front Mount Intercooler
17"x8"x3" Bar & Plate Core
23.5” x 8” x 3” from endtank to endtank
2.5” Inlet & Outlet’s
APEX’i Super Air Fuel Converter II
turbonetics evolution wastegate
Equal Length Header
Walbro Fuel Pump 255lph.
SR20DET 370cc Fuel Injectors
Hks hi power 65mm catback
And fidanza flywheel.
958Rocky
10-07-2004, 07:31 PM
cool setup, I have no clue how much power it makes though.
Why do you have a header if your running a turbo?
Tougeman
10-07-2004, 08:02 PM
yeah might wanna go up 15mm or so in exhaust piping too
musicsurfman
10-07-2004, 08:39 PM
its a turbo header... and before anyone chimes in a says if its turbo its a manifold, well technically anything roundtubed for exhaust is a header.
Pavlo
10-07-2004, 08:43 PM
Does any one know where can i get equal length turbo manifold, i have seen them ans searched for one called i think Espelir, but i can't find it anywhere in google forthe sr20det (found lots of exhausts thought) The setup is closely to what I want exept i want to build it as well, i mean you can get nice parts for 1000 (rods and pistons) from pauter and JE. And for that extra 1000 you can get like 200 more horses with high boost and a nice intercooler and gasket.
ImPLiCiTS14
10-09-2004, 11:04 AM
thanks hehe
nissanfanatic
10-09-2004, 12:17 PM
I did the math and got 260hp at the flywheel. Assuming a 19% drivetrain loss, 210. The flywheel will probably give about 15hp back to the wheels. The intercooler is usually worth about 20hp. So you are looking at about 240-250whp. Almost enough to need an injector upgrade. Not a bad idea to use the 550ccs.
Pavlo, what do you mean you can't find one for the SR? Greddy, HKS, and pretty much all the big name companies sell equal-length manis for the SR.
http://www.hksusa.com/info/?id=2081 scroll to turbo components
http://greddy.com/ go to JDM parts and scroll down to turbo upgrades.
http://www.jgycustoms.com/240sx/exhaustmanifold.htm
I'm tired of looking, but I'm sure there are more out there. Good luck.
