relay locations
chcknugget
10-06-2004, 08:50 AM
I know the ac relays are on the firewall inside the engine bay, but does anyone know what the relays in the glovebox are? More specifically - where would my brake light relay be?
thanks
thanks
chcknugget
10-07-2004, 02:56 AM
Haynes (booo) has none of this stuff. Anyone know if there are relays for the light?
Gooseneck
10-08-2004, 03:43 PM
I'm not very familiar with GM wiring but I don't think the brake light circuit would be a heavy enough circuit to need a relay. I would guess that the circuit is wired straight from the switch to the lights.
chcknugget
10-08-2004, 05:21 PM
I would think that would be a lot of current going through a switch. Wouldn't it get hot?
Cujster
10-15-2004, 07:41 AM
According to the Helms manual, the schematic indicates that there is no relay for the brake lights, only the stop lamp switch located under the dash. However, there is a relay for the high mount stop lamp on some S10 vehicles, I can't be sure whether this is for just the pick-ups of includes the Blazer.
This relay is in the underhood fuse block
chcknugget
10-15-2004, 11:48 AM
where under the dash is the stop light switch?
My 96 Jimmy doesn't have an underhood fuseblock - it has 3 underhood ac relays though. My fuseblock is in between the driver's door and dash
thejacobhartman
10-15-2004, 11:51 AM
the switch is located at the top of the brake pedal.
