Main Seal leak
metalman1045
10-05-2004, 12:57 PM
1999 neon sport with 2.0L DOHC what kind of job is it to change a rear main seal? Could you give me a short walk trough of the procedure? And any specail tools needed.
Zom
10-06-2004, 12:54 PM
You should go buy yourself a Haynes or Chiltons repair manual. It gives step by step instructions and has illustrations.
98R/TDailyDriver
10-20-2004, 09:07 AM
Are you sure its your rear main thats leaking??? If you can't pinoint it then don't do it. I had the oil pressue sending unit pissing oil -I thought it was the seal, luckily I replaced the sending unit and no more leak!
mprtech
10-20-2004, 10:10 PM
Rear mains are relatively commonly replaced seals for neons. To replace it you would need to completly remove the trans, then flexplate then seal. You need a special tool to install it correctly.
