ZC DOHC Valve Cover removal
Onimacus
10-04-2004, 06:06 PM
I tried to search the forums for this answer, but you can't type in ZC so its hard to find any information on them... I also looked at http://www.binghamtonlife.com/manual/2gsm/default.htm but its not for the ZC...
I want to remove my valve cover so i can start replacing the gaskets and what not, I unscrewed the 4 bolts on the four corners of the valve cover, but it looks like there is one more on the left side of the valve cover next to the dizzy, in the vally part where the spark plugs go, but on the very end. It also looks like part of the dizzy is also attached to the cover?
I was told its only 4 bolts to remove it so I just want to make sure I am doing it right... Does this sound right to you guys?
TheSilentChamber
10-04-2004, 06:54 PM
tap on it with a hammer and see if its just not stuck
Onimacus
10-04-2004, 08:11 PM
ok, there were like 9 screws to unscrew, and i found why there is oil in the spark plugs, there are no plastic rings around the first and second spark plugs from the left, and they are the two with oil
EDIT Ok i lied, the other two were in the valve cover....
91civichatch2571
10-04-2004, 08:57 PM
Just so you know, the gaskets that you'll need for the head gasket and up are the same as an 88-89 integra.
