Driver Auto Window Prob.
mikesvolta
10-04-2004, 12:38 PM
The power window switch for the driver side in my '97 accord doesn't work. It still powers all the other windows in the car. I got a new switch and it still wouldn't work. When I hook a battery up where the switch hooks up it powers the window up and down. I have no idea what the problem could be. Can anyone help me?
94accordVTEC
10-05-2004, 01:08 PM
if you know the switch is good and, using the battery, you know the wires from the switch to the window motor and the window motor it self are good...then by elimination it sounds like the switch isn't getting power to it or there is some problem outside the switch-window motor loop...buy a manual and look at the wiring diagram
mikesvolta
10-06-2004, 12:35 PM
The wiring diagrams don't have the driverside they have the passengers. I thought it could be the power to the switch but how would i fix that
mpumas
10-07-2004, 11:13 PM
Each window has its own fuse in the main fuse box in the engine compartment. It is a 20amp and may be blown. Power comes to the switch on a wht/yel wire.
mikesvolta
10-11-2004, 01:55 PM
Thanks for helping me, I got it to work
