Confused?!
RedLineZO6
10-02-2004, 11:12 AM
Ok... I'm all sorts of confused now....
Do the D15 and D16 have different heads? if not... how is the D16 a 1.6L?
Do they have different blocks? and it IS possible to just put MPFI on the D15 head right? and if I wanted to put the cam from a D16 in there... Would it be easier just to switch to the D16 head?
and some of you guys crushed my dreams of riding the DOHC train... lol... I really wish I had the money to throw together a Ls/Vtec... DROOL! But I'm still considering sticking with the D-Series and turbo'ing... or maybe even NOS... but I don't like Nos... everyone has Nos.... Turbo's sound so much sexier....
But anyway.... I'm sure I'll come up with more questions... But if anyone could answer those for me... that'd be great.
Shaguar47
10-02-2004, 11:20 AM
Yes, they have different heads. That's what makes them different.
And the D15 is a 1.5l cause of the 15 in the engine name. Same with D16 being 1.6l. It's not hard to understand.
-Yes, they have different blocks due to the liter size.
-Yes, the mpfi can be swapped with a d15 since it has DPFI (dual point) It's a very popular swap and there's info on here if you just use the search feature
-Yes, the cam from a d16 will fit on a d15. It's a little more aggressive and will pull better but don't look for a faster engine. Best thing to do is the MPFI swap and then the cam, then you'll have a d15 variant of the D16.
Hope that helps
mellowboy
10-02-2004, 11:38 AM
The heads doesn't have anything to do with engine size. D15 i believe has 8 valves while the d16 has 16valves :)
vladlos
10-02-2004, 12:06 PM
no man, i have a d15b1 and it has 16 valves
Shaguar47
10-02-2004, 12:08 PM
D15B1 or 2 and D16A6 = 16 valves
D15B6 = 8 valves
mellowboy
10-02-2004, 01:08 PM
I thought he was talkin about the hf motor.
quiXilver
10-02-2004, 02:04 PM
Hope that helps
Yea that's what I had, D15b2 with Si cam and MPFI swap. Pretty peppy.
91civicDXdude
10-02-2004, 02:23 PM
omg... an engine size is determined by its bore & stroke & number of cylinders. a 1.6L is a 1.6L becuase the stroke is longer than on a 1.5L. all d series have identical bores.
RedLineZO6
10-02-2004, 02:36 PM
alright thx!
So swapping my d15 for a d16 instead of just doin mpfi swap and cam swap would give me even more power right?
TheSilentChamber
10-02-2004, 09:19 PM
d15b2- 92hp d16- 103 (I think) theres not enough differnce that its worth doing a whole swap over in my oppinion.
Hilikus Funkin
10-02-2004, 11:12 PM
save ur money up for a B16, but in the meantime so the mpfi swap (youll need it later)
