Problem! Need Help Fast!
ModifiedCars04
10-01-2004, 07:39 PM
HEy guys, My mustang when cranked, WILL NOT shut off, In fact I can turn the key to the "off" pos. & it still runs & even pull the key out, My dad & I have NO CLUE whats wrong, PLEASE RESPOND ASAP, its still running
stang_racer20
10-01-2004, 08:03 PM
Sounds like your starter relay is stuck on. Try giving it a light tap w/ a hammer to se if it does anything. If it does help, you'll need a new relay.
ModifiedCars04
10-01-2004, 08:10 PM
Thanks man, I have to choke it to let it shut off, the power is still on so i'll go try that
StangNut86
10-01-2004, 09:22 PM
hmm... are you saying that it cranks continuously and doesn't start, or runs continuously and won't shut off? if the latter is the case then you're experiencing run-on, a common phenomenon when using an MSD ignition or the like. if that's the case you have to rewire the MSD's power wire into your car's voltage regulator, instructions for which are on msd's website if i'm not mistaken. if your ignition is still stock, i dunno what to tell you except get a new ignition switch (on the column behind the key cylinder).
wildstringer
10-01-2004, 11:09 PM
I was wondering the same thing . I agree with both the possibilities depending on the symptoms. if you turn the key to the run position without starting and the dash lights come on do they go off when you turn the key off
silverstangs
10-01-2004, 11:16 PM
I wonder what mustang he is talking about........
ModifiedCars04
10-02-2004, 01:28 PM
I have a 95 Mustang GT, basically, it dosent wont to crank, the key is hard to turn, then when you go to turn it off, you can turn the key COMPLETELY OFF & REMOVE it, & the car still has Electrical, & is still running, My dad thinks the switch is broken, The car was totaled, then restored, Guy we brought it from totaled it & was a jackass, Could this be why? Jokeing, but seriously, I tried the hammer thing, didnt work, I have it sitting in the driveway w/ the clock on... help please!
andrewespo
10-02-2004, 02:25 PM
Disconnect the battery until you figure out the problem.
GTStang
10-02-2004, 02:59 PM
I think I have the answer to ya prayers.... it's your ignition switch module.... The slide switch on it has become misaligned or disconnected someway.
Example my ignition switch module bracket was bent in a way so that the whole thing could move and the slider would not stay in the on position so when I let the key snap back it would move the slider switch to the off position and car would shut-off. I just peened my bracket so it would stay like it should and problem solved. Sounds like yours for some reason is stuck in the on position.
ModifiedCars04
10-02-2004, 06:38 PM
ok well, hereas what my dad thinks, he says that the pin that starts the car, Goes in when you turn the key, then when you turn it farther, it cranks the car, then pulls it back so it wont sit there going "zzssssssssszzzzzzzzzsssssss" trrying to start the car, when its already started, but then, when you turn the key back, the pin doesnt come back with the key, it stays in that position, this is what my dad thinks
GTStang
10-02-2004, 11:46 PM
I dunno but you saying that it keeps running and you still have all electrical on screams ingnition module slider switch to me.
ModifiedCars04
10-04-2004, 04:10 PM
no clues?
91notchback
10-04-2004, 07:09 PM
i agree with you my frieds ranger did the same thing
ModifiedCars04
10-06-2004, 06:28 PM
well my dad seems to think takeing apart the ENTIRE steering colum will fix it :shrugs: couldn't stop him
