HELP! please reply :)
metalhead152
09-30-2004, 03:02 PM
Hi, my subaru wont idle!!!, it will rev up and everything but the second u let of the gas and puch it again it will stall, I already got a carb kit for the thing, and replaced the fuel filter.
any ideas\sugestions would be very helpfull, since im planning on selling it :) (running or not)
Cornerbuddy28
10-19-2004, 09:58 AM
It sounds like you might need to get new injectors. They could be clogged or dirty. If the fuel supply to the engine isn't sufficient at low RPM it might be hindering its abilty to keep on turning over. You might want to get that checked out. I'm not sure that this is the problem but it's all I could think of. It could also be a fuel pressure issue.
heartless
12-07-2004, 07:12 PM
first off, need more info on the car - yr? engine? carbed/fuel injected?? I am gonna guess carbed, since you mention getting a carb kit....
It could be your idle mixture is off, it could be several other things...more info would help in making the diagnosis.
