problem with '89 windows
equalizir
09-29-2004, 07:34 AM
Hi All,I got and '89 crx si.The problem im having is when I roll up my driver sidse window it rolls up all crooked.I have to manually hold the window straight so it rolls up properly.Anyone have this problem and what can I do to fix it?Thanks in advance.
icE_x
09-29-2004, 08:15 AM
I think the window is off the track. Someone here has a diagram of the windows for ya to check out and fix.
johnb16a2
09-29-2004, 08:18 AM
This happened to me too. The window has two mounting points glued to the bottom of the glass. The glue gives way and the glass flops around as you roll the window up and down.
You have to take the door panel off and you may be able to glue it in from there. Better if you take the glass out and re-glue the points. If all this sounds like it's too much, any glass shop should be able to repair it. GL
johnb16a2
09-29-2004, 08:24 AM
Also check
Here (http://www.binghamtonlife.com/manual/2gsm/body.htm)
GL
