Coolant Level Low
Jim Rockford
09-23-2004, 09:26 PM
i've got a 93 lss and the information center keeps saying COOLANT LEVEL LOW and the coolant is fine but this is always showing up on the information. Is there anyway to fix this?
twisted_metal
09-24-2004, 11:24 AM
I have a 1993 LSS and I had the same "Coolant Level Low" message a couple of months ago. I found that the coolant sensor just needed to be unplugged and reseated. Your sensor could be bad too. It is located at the top of the engine (drivers side, rear corner of the intake manifold). The little clip that holds the connection tight had been broken on mine when I had a cracked intake manifold replaced last spring. Good Luck!
Ofnarcr
09-27-2004, 03:44 PM
I dont know but my coolant looks all brown. Is that normal??
auto trainy
10-07-2004, 04:36 AM
I would have a pro look at it to make sure your not getting coolant mixed in with the fluid,soon.
