'95 Blazer mirror & wiper problems
Todd6590
09-22-2004, 07:01 PM
I have just bought a '95 Blazer at a Customs Auction. Neither the front wipers or the power mirrors work. Is this problem related and/or how do I fix?
sinzn0more
09-22-2004, 08:29 PM
i have a 97 blazer and both problems you explained i also had lukily there was a recall on the items contact your local chevy service center to see if this applies to you Good Luck
BlazerLT
09-22-2004, 10:36 PM
Check for blown fuses in the fuse panel in the driver's side end of the dash.
Look for all burnt fuses.
Todd6590
09-22-2004, 10:44 PM
Thanks, the fuses were actually the first place I looked. Everything looked fine, but I replaced just in case. (Although I didn;t see a specific fuse for the mirrors. Is it part of an acc. cluster or something?) Still nothing. Any ideas what my next diagnostic check should be?
BlazerLT
09-22-2004, 11:02 PM
Did you check the fuse map on the panel door?
Todd6590
09-22-2004, 11:37 PM
Yeah, but nothing that specifically indicated mirrors. As a matter of conservatism, I pulled all of the fuses to visually inspect.
Sidebar question: Is there an easy way to replace the middle sparkplug(s)? On the right side the steering linkage seems to be in the way. On the left side the fit seems to be too tight for me to get my socket in. Any advise is appreciated.
BlazerLT
09-22-2004, 11:41 PM
Middle sparkplug on the passenger side is easy to get to through the wheel well.
Driver's side is a pain in the ass.
Best way they say is to like up the boot at the bottom and diconnect the steering shaft bolt and push the steering shaft out of the way to get at it.
Other than that, the best way to again get several long extensions and elbows and go through the wheel well again.
It takes some time, but it will be worth it.
BTW, use antiseize on the plug threads for easier extraction next time.
