Motor/Transmission mounts
mikede14785
09-21-2004, 08:03 PM
Has anyone had to install motor/transmission mounts on thier 2000 deville??? After how many miles. My caddillac dealer says mine need to be serviced?? Whats that mean.
MagicRat
09-25-2004, 10:49 AM
This sounds a bit suspicious to me. Usually it takes many years and miles to wear out thses mounts.
mikede14785
09-25-2004, 02:42 PM
Thats what I thought. I've only got 45,000 miles on the car.
maximagirl420
09-29-2004, 08:05 PM
I have two Cadillac Deviles. Both are at 190k. I just replaced the 4 motor mounts on the '90 at my work. The '89 needs them too, but not as bad as the '90 did. And these on a Caddy are NO fun to work on.
It is about a 5-6 hour job, and my work charges over $600, and were're not even dealership. I doubt you need yours replaced. If it's not "clunking" hard when you take off fast from a standstill, you are probably OK. If your tranny does seem to be shifting hard into any gears, then maybe they are bad. But keep in mind "bad" is a relative term. If you do have them replaced make sure you ask them for the old mounts. This is one of those repairs that are easy for a dishonest mechanic/dealership to lie about.
freyr02
10-12-2005, 02:33 PM
sorry to drag an old thread up, where are these mounts situated?? i have an 86 deville which klunks when put into reverse and sometimes when you pull away hard.Love to know how to change them!!!
