Del Sol Automatic Roof Closer
johnmcgazza500
09-21-2004, 09:05 AM
Hi everyone
Coming from Australia, there ar'nt a lot of Del Sols around (and not a lot of information) But i Have just picked up a 1993 Del Sol B16a. I have only seen these with a hand removable to (targa style) But my boot lid lifts up vertically to pickup the roof, and folds back down into the boot.
I have not seen this before on any pictures of this model car. Does anyone know if this was a feature on some Del Sols. It doesnt work (wiring is an absolute mess, but will try to sort it this weekend)
Any pics or info would be great - will try to post some pics when i find a digital camara....
stook02780
09-21-2004, 09:08 AM
i've seen pics in the galleries of www.teamdelsol.com
also read the FAQ under information for the different models/features
toozious
09-21-2004, 09:46 AM
Hi everyone
Hi mate,
I have a UK spec 93 Sol b16a with the "transtop" style roof you decribed. I'm slightly confused that you said it folds back as this model slides into the uplifted roof section.
I had a small problem with mine (it was noisy) but managed to get it fixed by a very good mechanic for £10. The "breaking" cable was loose and just needed tightening!
Honda charge around £2000 for a new unit (probably about $5000 AUS) - which isn't cheap, and any trashed Sol's you find in the scrap yard are normally striped of this unit as they are quite tricky to get hold of.
I personally prefer the transtop to the targa, as although it's heavier, it is sooo much cooler.
I would suggest doing some really good research on the internet (as I did) and finding someone that has fixed these roofs before - or you'll just get led around by the nose until your wallet is empty. Alternatively, (and I have considered this) strip the whole system out and you'll remove about 100-150Kgs, not exactly sure how much it weighs.
If you were in the UK I'd be able to help you much more, but considering you're the other side of the world there's not a lot more I can suggest.
I hope this helps anyway.
Here's some pics of my roof going up and down:
http://www.voodooz.com/car_photos/158-5843_IMG.JPG
http://www.voodooz.com/car_photos/158-5844_IMG.JPG
http://www.voodooz.com/car_photos/158-5845_IMG.JPG
Thanks,
Jonny Tooze
Plastic_Fork
09-21-2004, 11:35 PM
Hi everyone
This is known as the "transtop". This was an optional feature on EDM and JDM Del Sol's. USDM Del Sol's did not get this feature. Del Sol's that didn't have the transtop had the manual roof.
Typically, they're expensive to fix but a cool feature. :)
johnmcgazza500
09-24-2004, 07:59 AM
Thanks guys for your input
If anyone else has some information (or has any expirience or diagrams )wiring this very cool feature would be muchly appriciated
Im borrowing a frineds camara this weekend, will try to get some pics up, but until then it looks almost identical
to yours jonny, but with gold Speedy 5 spokes, and a mild blitz bodykit.
Plastic_Fork
09-27-2004, 02:03 AM
Head over to the Team Sol forum in my signature. There's a couple people there with transtops that have had to go through the repair process that should be able to help you out.
And here's a better look at the transtop in action.
http://www.honda.co.jp/MotionGallery/cr_x/
johnmcgazza500
09-27-2004, 06:44 AM
Thanks for your help plastic-fork
i will go there - but now i have more probs - engine light is on!!!
Where is the ECU in JDM's (right hand drive), and how do i find out what is wrong. i have tried disconnecting to battery for a while (10min), still coms on. checked engine, its running normally
cheers for your help in advance
Gazza
johnmcgazza500
09-27-2004, 09:12 AM
Dont worry found info on a P30 ecu, and just restted it, works fine, hope for the best!!!!
anyway iv just got photos for the world to see
Car is booked in at fibervision to get the blitz bodykit fixed on wed
aussie_legend
10-08-2004, 07:54 AM
hi, im from Australia also - Sydney. i recently bought a del sol with the transtop also. the person i bought it off spent $2500 fixing the broken roof - they had to get that part from Japan that was mentioned earlier. (now it has a warranty :))If you want a good job done and you live in sydney go to Scotts Honda at Artarmon. They shoud be able to help and maybe cheaper as now they have already fixed one roof and now may know what to do. I think alot of the cost was just finding the problem.
Good Luck
johnmcgazza500
10-12-2004, 07:50 AM
Yeh thanks Aussie Legend, but unforntunetly i live in perth (West Coast, other side of australia for those that you dont know) I have since found some of the faults with the wiring, trying to save some money and do it myself. have found a brokem motor and a few dodgey switches (generic thank god) am getting quotes to get them replaced and will install them myself, hope for the best
Its a great function though hey, cant wait till i get it fixed properly for summer.....
hehehe
oh yeh bodykits fixed and looks immaculate....
