In Need of HELP 92 Thunderbird
Diamond615
09-19-2004, 02:39 PM
I am in need of help. I have a 92 thunderbird. I has 51,000 orginal miles on it. I was driving to work and the odometer stop working. Is it run by a regulator. I do know that it is on the transmission. But I need to fix it. In need of some idea the garages around here are expensive!!!!
Scott Long
09-22-2004, 05:17 PM
the odometer itself or the whole speedometer. The odometer runs off the speedometer. If its broke, replace the speedometer unit. You can get one from a 94-95 SC that reads to 145 mph and it plugs right in and will work with no other mods assuming you have an SC or atleast the 120 mph w/ tach gauges.
STINKINLINCOLN
09-22-2004, 07:47 PM
are you thinking of the speed sensor ?
that sets on the transmission
Scott Long
09-22-2004, 10:18 PM
If the whole thing stopped working it may be the speedometer tooth gear in the transmission. Not hard to change.
Diamond615
09-24-2004, 06:27 PM
The odometer tell us how many mile the car has traveled. The trip milage is not working either That is what is not working the speedometer is still working .
Diamond615
09-24-2004, 06:29 PM
The speedometer works. Odometer and trip miles don't work.
Scott Long
09-26-2004, 03:04 PM
It's internal then, the speedometer head itself might have a stripped gear inside. You can go to Ford and order a new one and tell them how many miles you have or expect to have in say a week and it will come set to that reading. Or if its not a big deal to you just leave it as it is.
Scott Long
09-26-2004, 03:06 PM
try driving down the road and push the reset a few times see if its starts working again. I've had the trip meter not read for a while but a little fiddling with the button makes it work. But the top odometer itself has always worked on my birds. one of them now reads 200718.6 miles.
thunderbird muscle
09-26-2004, 04:41 PM
My old 92 did that. I just never worried about it.
Diamond615
09-26-2004, 06:36 PM
That did not help I tried that. The odometer does nbot work it only has 58,000 orginal miles on it. My Great uncle own it. when I got it. it only had 38,000 mile. What would make it stop working.
RickwithaTbird
10-05-2004, 03:03 AM
I bet that'll solve the problem, plus a 145 speedo would be cooler anyways. And on that subject... would those SC gauges fit in a 96 LX?
